mechanical to electronic speedo adapter?
9 Second Club/LS1TECH Sponsor
Yes, I think it's around $300. John B has it on his Monte I believe.
It's here:
www.abbott-tach.com/products.htm
It's here:
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic1124_1.gif)
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
Chances are this doesn't exist, but I thought I'd see if anyone had seen/used one...
I'd like to continue using my mechanical speedometer, because I don't want to rebuild my dash. However, I'd like to get the speed input into the PCM so that I could use the cruise control from the PCM. The car has a vacuum operated cruise control on it which I could use, but I thought it would be cleaner to use the electronic one from the computer - less controllers, hoses, etc in the engine compartment.
Anyway to do this, I need an electronic pulse generator that I can run my speedo cable through. Basically, mechanical in and out, with a electrical output as well.
Anybody seen anything like this?
Thanks!
Perry
Thanks!
Perry
Hmmm...
That looks like it will drive my speedo if I have an electronic signal. Unfortunately, I need a something to generate the electronic signal. (damn antique cars!)
Maybe I can put a reluctor wheel on the driveshaft and mount a sensor for it. Does anyone know the tooth count on the reluctor wheels that are in the T56 or 460E?
Perry
Perry
Kinda confused what you need, but this might help.
if you need a mechanical signal from a T56 try this site, www.jagsthatrun.com
Ryan
Ryan
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">John B has it on his Monte I believe.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sure do and it works very slick...especially when I changed to 4.10's....instant speedo recalibration via flipping a couple dip switches <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
