VSS signal and scaling
Does anyone know what the speed signal is used for besides the cruise control and speedometer output? Is it used for other engine control functions? Is the VSS required to make the engine run correctly?
Does anyone know what the VSS (vehicle speed) signal is, and what scaling it has by default in the PCM?
Is the signal a DC square wave, or an AC type signal?
What is the standard scaling for the signal in the PCM? In know that the reluctor ring on the tranny output has 40 teeth. I figure this to give us about about 8000 pulses per mile with average rearend and tire sizes.
I know we can change the scaling using LS1Edit to adjust for rearend and tire changes. How much of a change can be made?
If I find a speed sensor that only gives me 4000 or even 2000 pulses per mile, can the PCM be adjusted that much?
Thanks!
Perry
WITH a VSS the PCM sees the same conditions as above, but now it makes a different decision; "I see zero throttle, high vacuum, high RPM, AND a VSS signal, aha we're coasting, don't close the IAC, the high RPM is correct!"
The VSS signal out of the transmission is basically an AC sine wave. Out of the PCM it is a conditioned square wave.
It seems like you are low by about a factor of 5 on your PPM number, but my brain is already off for the night. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
You can change the scaling quite a bit with LS1 Edit, but what I've found is that if you aren't using a GM electronic trans anyway, the accuracy isn't that important, just that there IS a VSS signal of some sort.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
The VSS signal has one side grounded at the PCM (VSS LOW). The PCM takes the VSSHigh signal and modifies into a square wave and outputs 4000 pulses per mile for use by the speedometer/cruise/radio and miscellaneous others.
