Ok, newbie question(s)
Thank you for the help guys, I am sure I will be needing lots more in the future!
Jimmy <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
I used S&P motor mounts. If you can fabricate headers thats good. You got to use mod. T/A Camaro oil pan. I beleive Speartech Fuel Inj. syst. can make the trotle work but I dont know if you can incorporate it with aftermarket computer. For the gas pedal you can get Locker pedal or mod. your gas pedal.
Let us know how your turbo setup is bec. that's crossing my mind to. You might talk to John at speartech about using stock computer if it is good for turbo set up.
With the engine management, I plan on using a FAST setup, since I have NO computer or harness now.
Jimmy
Corvette Throttle Body
F-Body Throttle Body
I've got some pictures of the lokar stuff on my website somewhere. I can take some more detailed ones if you want.
- Jeremy
Jimmy
Doug
Jimmy <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
We had some issues with the cam position sensor version of the FAST setup on a C5-R project at MTI. Ended up returning that setup and going with a crank trigger/sensor type setup and it worked great.
The LS1 should buy you some flexibility on where you wish to mount the engine. It can sit much closer to the firewall than a traditional SBC because there is no distributor in the back.
-Tony
If you work at MTI, I will prolly be asking you a few q's in the future!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The car is in the latest (March 03)issue of Chevy High Performace with a feature of it in the previous set up. You can also see pics of it at www.pro-touring.com in the cars section under first gen Camaro's and under Jimmys twin turbo Camaro.
What are you talking about with the problems with the crank trigger? Is it with the computer options or with the actual engine sensor? You have to forgive me, I have never messed with an LS1, or fuel injection and computers for that matter!! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Jimmy
http://pro-touring.com/featured_cars...o_69_camar.htm
Track times have changed a little since then.
hey, i live in houston, and my brother has a 99 SS with Vortech, heads and cam all done at MTI. If you do work there, give, e-mail at DougieC14@aol.com to see if yall would be able to do some of the work on my 69 there or at least just get some help.
Thanks
