another exhaust thread: 3" too big?
-Gordon
Too big and you lose alot of torque on the low-midrange, unless you install some very expensive merge collectors on the headers, which would require the least amount of backpressure beyond them.
Tony
Frank
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Too big and you lose alot of torque on the low-midrange, unless you install some very expensive merge collectors on the headers, which would require the least amount of backpressure beyond them.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The ONLY reason your combo is working is because you have those merge collectors. Remember that C5s have true dual exhausts (2.5") and we have extensively dynoed tons of different combinations with the factory midpipe and with a custom 3" X-pipe equipped midpipe setup (both longtube setups with aftermarket catback, as well as dual cutouts).
Dual 3" midpipes killed low/midrange torque on those Vettes on anything less than 475-500 rwhp. They also had a more peaky looking HP curve instead of the nice broad curve.
When Judson first ran 10s in his 346ci car, he tried and tried to do it with dual 3" exhaust, but actually went quicker once he put some 2.5" reducers and went with dual 2.5" . I did the same thing and also went quicker.
Tony
I certainly can't argue with your or Judson's results but then again, I have always tried to optimize my complete exhaust as a system, not just the pipe size. All I know is that if you pick up power when your system is disconnected then you had better do something about it like enlarge it. Since open headers display the ultimate "no backpresure" I find that a good exhaust system should duplicate this. If the power falls off, then something isn't engineered correctly.
