LS6 Cobra
Old Nov 28, 2005 | 04:34 AM
PaulFLS6's Avatar
Default LS6 Cobra
I have recently tried to start my LS engine which is installed in a Cobra Kit Car, and have used a Baker Lim module with this installation.
I am pretty sure that the module is all wired in correctly. Although the engine is an LS6 I am using an LS1 PCM and wiring loom (for the mechanical throttle), from a 1999 vehicle.
I have got a spark at the engine, and fuel as far as the fuel rails, but there is no sign of life. This makes me think that the fuel enable signal is not reaching the injectors, and the VATs signal seems to be the starting point.
Could you tell me how I can test this theory, and if there any other tests I can carry out.
Old Nov 28, 2005 | 09:40 PM
steveo346's Avatar
wow post some pics of the project that sounds like an awesome car...sorry i cant help u with you question
Old Nov 29, 2005 | 02:50 AM
MOLESTER's Avatar
im not too sure on this but i dont believe that an ls1 pcm woul be the cause cause the eingines are basically identical extenally. try checking to see if all of your grounds are hooked up. thats the only thing i can think of. hope you get it running...
Old Nov 29, 2005 | 01:41 PM
92CamaroReallySlow's Avatar
Have you disabled the VATs on the PCM? My car would not start without disableing it. Other than that check all the grounds and fuses. I had one fuse blown, and I spent weeks trying to figure out why it wasnt working. Im not sure how you car is wired, but thats where I would say to look.
Old Nov 29, 2005 | 01:52 PM
69chevy's Avatar
Awesome project you got going on there. Good luck with it.
Old Nov 29, 2005 | 03:51 PM
Happy Jim's Avatar
Paul,
I'm as far through as you yet, however from what I've read here so far, my understanding is that VATS will let you start the car but only for 2-3 seconds - might be worth removing the baker module to start with?
Jim
Old Nov 29, 2005 | 05:46 PM
MeanGreenLT1's Avatar
my experience with vats issues in the past was that it wouldn't even let the engine run at all. would turn but woudln't fire off the injectors.
Old Nov 29, 2005 | 06:28 PM
BrandonDrecksage's Avatar
vats cuts power to the started and fuel pump..if the vats is on..nothign will happen when you turn the key..you have to get that **** tuned out..i just had to get a new key cause the original key took a **** on me and the vats came on.
Old Nov 30, 2005 | 04:32 AM
PaulFLS6's Avatar
Thanks for all the replies. I have discussed the issue with Baker Electronix, and it does not seem like it is the VATs causing the problem.
I am going to take out oune of the injectors and turn the engine over, (carefully) and see if fuel is getting into the engine.
If it isn't, as I understand it the PCM just switches the earth on and off, so I will check whether it is doing this or not.
I think I will just have to take the loom apart again and follow the wires back.
Old Nov 30, 2005 | 05:49 AM
PaulFLS6's Avatar
Here are some pics of the chassis, pre body fitment.
Old Nov 30, 2005 | 10:04 AM
NO CATZZ's Avatar
That is a sweet looking project. I bet that little car is going to fly...and handle like crazy. Good luck with the VATS and when I get home tonight I will look through my GM manual and see if I can help you out. I have the 3 Volume GM F-body service manual for 1999 so maybe I can help you figure out what to do. I know that it is a combination of the BCM and PCM. The BCM has the fuel enable circuit in it which looks for the proper ignition key (with the little resistor in it) and then will allow the PCM to enable the fuel. Like you said, I think it is just an earth ground applied to the PCM.
Good luck
Josh
Old Nov 30, 2005 | 11:13 AM
PaulFLS6's Avatar
Josh,
Thanks for your reply. I should have a better idea what's going on once I have taken out the injector and tested it.
I look forward to hearing from you if you find anything.
The kit is built by a company in the UK called Gardner Douglas, (http://www.gdcars.com/).
It should be pretty quick as all up it will weigh about 950 kilos or less than a ton. Once this LS6 runs it should have plenty of power and an excellent power to weight ratio!
Paul
Old Nov 30, 2005 | 01:22 PM
PaulFLS6's Avatar
I have checked one of the injectors and it is not getting any signal from the PCM. Any ideas anybody?
Could the problem be related to the crankshaft position sensor??
Old Nov 30, 2005 | 09:11 PM
NO CATZZ's Avatar
OK, I just finished looking through my manual. The Theft Deterrent Fuel Enable Signal leaves the BCM on connector C2 pin D8 (not important to you because you are not using it) and goes to the PCM on C2 (red) pin 30. I have not figured out what the signal is yet but that is the pin. It is quite possible that it is just a ground signal that enables the PCM to drive the injectors. Have you verified that the fuel pump is coming on and giving 58 PSI?
I will keep digging and see if I can determine what 'signal' the PCM is looking for fromt he BCM.
Good luck
Josh
Old Dec 1, 2005 | 03:24 AM
PaulFLS6's Avatar
The injectors have a constant power supply. As I understand it the signal from the PCM provides the earth supply to complete the circuit.
None of the injectors are not getting this signal. The fuel pump relay is all OK, and there is fuel in the fuel rails.
I am wondering if the camshaft on crankshaft sensors could be to balme, but I am not sure how to check them. Any ideas?
Old Dec 1, 2005 | 04:15 AM
robin427's Avatar
Just a note for our American cousins, Gardner Douglas has an American arm www.gdcarsusa.com
I've got a GD427 with an LS1 in it and yes, they are very quick!!
Old Dec 1, 2005 | 07:08 AM
NO CATZZ's Avatar
Well, I am back at work so don't have the manuals infront of me. When I get home tonight I will see if there is a precedure for bench-checking those sensors. If you can get your hands on some you could try to switch them out. I see them on ebay for 10-20 bucks(US) all the time.
Old Dec 1, 2005 | 10:05 AM
PaulFLS6's Avatar
Josh,
Thanks for your reply. Hopefully there is something in your manuals!
Have a good day at work, in the meantime.
Paul
Old Dec 11, 2005 | 09:53 AM
robin427's Avatar
Paul,
Sorry we couldn't get it going today. If it's any consolation, mine flew on the way home (calculated about 15mpg, but that figure isn't quite correct - I'll need another fill up before I can get an accurate figure).
Racking my brains to think of what the problem could be. I'm sure it's something simple as the fuel pump seems to be working OK, and that is triggered by the PCM. Will let you know if I think of anything in the meantime...
Robin
Old Dec 12, 2005 | 03:48 AM
strokedls1's Avatar
I had a bad cam shaft sensor, and the motor still ran. It ran like garbage and spit fire out the exhaust, but it ran. I would think the crank sensor would be more of a suspect. The crank senors just times the #1 cylinder, and the cam senor takes over the timing for the rest of the cylinders. Check that all grounds are good also.
