s10 ls1ers
#62
i was only hopin to run the stock tranny til next summer then i was gonna get a built one. im lookin on ebay, i think i can get a ls1/4l60e package easily. how much do u think a shop would charge for custom headers??
#66
Originally Posted by XtremeDime
maybe ill get those long tubes off of ls1performance.com
'JustDreamin'
#67
gimme some details of ur swap ls6. the cost and stuff
As far as headers I went with shorty's(Sanderson) for now just of the cost of somebody fab up some LT headers. Fuel lines I used braided everything and ordered my fitting from Street and performance, Zac @ speedscene wiring did my wiring, using a 9" ford for my rearend, Used street and performance maf/air filter kit instead of trying to create a CAI kit there's is alot cleaner, costly, but cleaner. Custom motor mounts and k-member(f-boby mounts doesn't work for blazer/jimmy but somehow works for S10's) Complete corvette front accessories.
Future plans 6L80 and a few more cubic's
#70
Dude, sorry I'm late but I haven't been on much. First of all, DON'T USE LS1 Performance Parts! Search for my threads and others about them. Next, depending on what you do yourself and buy your looking at about 8K and that's probably on the low side. You can use your stock 4l60e you just need the bellhousing from an LS1 tranny. If your looking at custom headers your gonna spend at least 1300K with them coated. Since you have an extreme it won't be that hard since your not fighting with your 4wd. I'm not sure for the rest of the drivetrain but mine bolted back up stock with my crossmember with no modifications at all. Just bolted the motor and tranny together and set it in like that using the crossmember bolts as the guide. Your PCM will work, work with Jered at CPW, he's great and got me setup. The wiring will be more then what you stated, it's gonna be around 800 probably with a reflash. Let me know if you have any specific questions about the swap though. Mines done though. Just have to update my threads and pics. I just got the silicone elbow for my intake I'll be putting on this week and fine tuning it. Search for my LS1 Zr2 swap in here. Unless you have everything in place and ready to go it probably won't take you a month most likely longer just for little **** that is bound to happen. If you plan well though it's only about a 40 hour job believe it or not. Good luck
Chris
Chris
#71
how do you get 8k? i added up all the essential stuff and im at 4k or so. im also looking into this FAST efi thing instead of a wiring harness and reflash. i did see your swap thread, very nice. good to see a fellow mini getting an ls1.
#72
do u think i would be better off payin 400 for the conversion pan or just modifying a diff one. i read something about ls1performanceparts, but i dont know im gonna keep talking to em.
#73
With the FAST EFI, it's entirely up to you to make the gauges and the rest of the truck's electronics function. I hope you know wiring.
Wilds... glad to hear it's up and running. Did you use your S10 tansmission? I still haven't found anyone that actually has done it, I have heard that there is an issue with the torque converter and flexplate holes not lining up and an adapter is needed.
#74
#75
Chris
Chris
The stock S10 4L60E bell housing is approx. 1/2" shorter than the LSxx housing and the crank face is about .400" farther away. The LSxx TC has a different spline than the S10 TC and has an extended pilot. The LSxx pump stator is longer and the input drum has a longer shaft.
The only fix is to use a LSxx housing, a LSxx TC, new pump stator, and a new input drum.
#78
from wat i heard you just need another hole drilled.
#79
Originally Posted by randyc
I have just been through this exercise, including what you have just suggested. Put the trans in, no drive, TC was not engaging the pump.
