my rx7 engine/trans debale
let me explain what my goals are: a reliable efi street/strip car that i can also take to an autocross or two. probly 50% strip, 40%street, 10% AX. for 1/4 mile performance, i'd like to start in the 12's & work down to the high/mid 10's eventually.
i'll be running no A/C & manual steering, so my only driven accessiries are the water pump(may eventually go electric) & alternator.
engine- i'd like to go LS1 if i can afford it. but i'm considering a LM7 5.3l truck engine as well.(ther're cheap to start with, but have some additional costs)
i know the ls1 is better suited for what i want from every angle, except price.
to use a lm7 i have to use a f-body oil pan, ls1 intake, fuel rails, throttle body, water pump(i think), & alternator bracket. buying mostly used parts for this, what's the average cost?? anything i missed?
how much more does the 5.3 weigh? 75 lbs? how much am i going to be down on power, even running a bigger cam?
i could have the heads shaved to bump compression, how much does porting cost on these usually?
which computer(truck or f-body) is better suited to this type of tuning using one of the tuning programs? i don't have to deal with emissions either.
transmission: i'd like to have a street/strip setup... with overdrive. is the 4l60e suited for this? would i be better off running a 700r4? i'd like it to hold gears when i want to shift manually, but just be an auto still. can i run a trans brake on either? what are the pros & cons of the two? is there something better suited for it?
The cast iron block truck LS is not as important in drag racing, but the additional weight upfront can really screw up a light V8 car for cornering / handling.
Drag racing trans applications are easy, but an automatic is marginal for Auto-X and flat out sucks for roadracing track days. Rear end gears, posi, versus locker, all determine whether your car will be great at one function or the other or just marginal at both.
Important considerations.
right on the head... i used to have a 88 rx7 with a chevy 350, and damn that thing was a blast in a straight line... but it didnt take the corners all so well. i mean it did have iron heads and block and yada yada... but all that adds up. so just wait and save your money and get a ls1. you wont regret it bud
The 4L60E is supposedly rated for under 400 hp (around 350, I think), so a reasonably stock LS1 would not tax it too much. The problem I see in that tranny is the gear ratios - 3.07/1.66/1.0/.70. Nice first gear but a BIG jump to second, with fourth looking like a cruise gear only. Any autocross runs would be fairly slow (under 60 mph) and maybe you could leave it in first, but if it's a track day, this tranny just doesn't seem like the right tool.
I believe the 4L80E has even worse ratios, not a close ratio box at all. It's stronger, but no improvement for track requirements.
My $0.02,
Mike
I just hated my 7 with an auto. It was a granny car.
if i get it, i'll have to store it for a while until my brother gets his car on the street. i'll see what pans out this week.
plan is to be street legal, to be able to do some tuning on the street, use it for an occasional night out, and when we head for the drag strip or AX, one is always trailered so if one gets broken, it's not a big problem.
it's a 99 z28 ls1/auto, 110k+ miles, hit hard in the right side. guy slid it into the end of a guard rail. hit hard enough that the trans tunnel is crunched, the shifter is sitting at about 30* angle pointing toward the drivers side, and is bound up so it won't shift out of drive. dash & console are destroyed, but the airbags didn't deploy. it's been sitting for about 6 weeks in the rain now, so the interior is molding bad.
what's it worth?
my concern is wth it hit so hard will the trans be hurt? what about stresses on the motor?
with 110k+ what are my concerns with the motor? fluids looked OK, oil was dark, but not bad.
