max lift cam on yellow ls6 springs
hoe much can I go with yellow ls6 valve springs and non adj. rockers. and what is the easyest way to go adj rockers. Thanks Woody
I am not for sure the on your lift questions. But adjusting the rockers is easy if you have the stockers, just tighten the bolt down to 20 ft-lbs. when that cylinder is at TDC.
