turbo chevelle gettin there!
Mounted the intercooler off of the radiator support and modified the hood latch release to clear the intercooler and still function as stock. I was wanting to avoid hood pins and it looks like it's going to work out.
I also made up a fan shroud and mounted two 10" permacool fans rated at 1250 cfm each. The shroud is kinda shallow, a little over 1", any opinions on this. I may open it up at the top more to allow some more air to flow when cruising, but would this affect the pull of the fans while in traffic?
And you'll need some wider wheels out back if you want it to ever hook up.
I love chevelles, yours looks great. What color are you planning on painting it?olly
I'm planning on running 315/35/17s in the rear on some 17x11s w/ 275/40/17s on 17x9.5s up front (I know it's been done to death, but I really like the look). The tires on there now were just to give me some reference points for measuring backspacing and whatnot.
I think I'm going to keep it orange although I might wanna go for a metallic sunset orange color. Like this
I really dig your paint color choice; I wish I had those sort of skills. Not sure what I'm going to do about bodywork...
What kind of boost levels you running?
Getting Closer!
Here's the gauge panel I fabbed up a couple of weeks ago (not too bad for jigsaw freehanding I think ):
It's obviously not done and will have a couple more indicator lights and different gauges in the panel (AFR, fuel press, boost, etc.). The others will go either in the dash where the radio would be or below in a panel.
Here's the A/C evaporator mounted up (must have in Las Vegas):
Max
Im planning a backyard turbo LS1 chevelle as well, and was going to put the downpipe through the AC Compressor area, but you have given me hope.
What AC system are you using? Are you able to retain both heat and AC with the downpipe routed high? Any pictures of that clearance?
Im selling my RX7/LS1 now, but once that is gone Im going to press ahead with a project.
Best,
-Jason
Not much room for the stock A/C box unfortunately and I'm not sure how you could make it fit w/o running a small downpipe. A twin setup w/ dual 3" downpipes might be able to fit but it would probably be tight. I'm running a Hot Rod Air setup; I heard good things about them from other forum members and they make an adapter to use the stock GM compressor setup although I had to clearance the crap out of the frame which I wasn't really keen on but couldn't figure any other way to utilize the stock compressor.
Like I said, I had to clearance the frame, which I still need to box in for strength, but there is plenty of room for the A/C and heater lines. I'll probably run them under the down pipe then up and over the inner fender and to a bulkhead that I still need to install on the firewall. I might even run them under the outer fender to keep them out of sight.
Max
Got some wheels and tires delivered this past Friday and couldn't be more happy with the look/stance.
They're American Racing Hopster wheels with the overdone 17x9.5 fronts and 17x11 rears. The tires are Goodyear F1 GS D3s w/ the also overdone 275/40/17s up front and 315/35/17s in the rear.
Max
1) I love the wheels. Do the 315s fit w/o minitubbing?
2) how are you routing from the turbo to the intercooler? Above the frame rail?
3) Do you have a website with the AC system? What about the heat?
4) Would you mind a phone call to talk over the setup? You are in Vegas right? Next time I am down there, could I possibly look the car over? I can bring a 12er for your time
"Made some more progress today...got one side of the cold side piping put together, just need to add the BOV and do the other side as well, hopefully tomorrow:"
