turbo chevelle gettin there!
Old Nov 11, 2006 | 11:27 AM
  #61
Whistler's Avatar
Sawzall and Welder Mod
That's aweome!! What state are you in? I'd like to see that car in person one day.
Old Nov 11, 2006 | 11:57 AM
  #62
350SS's Avatar
Las Vegas, NV unfortunately. Do you have any pics of your Camaro? It sounds sick
Old Nov 11, 2006 | 12:24 PM
  #63
pearceleather's Avatar
Originally Posted by 350SS
That was the easiest place for me to mount it off of one of the engine brackets. It's mounted with 1/4" angle iron to the alternator/p/s bracket for support. This was my first real fabrication/turbo build so it's been a learning experience, I would definitely do some things differently if I did it again. Pictures are always hard to see real dimensions in...the wastegate is about 1/4 to 1/2" away from the fan shroud so it should be okay I think. Hopefully things won't move around too much but it might be wishful thinking
I hear ya, that is really an undetaking. There is a ton involoved and yours looks great.
I only asked about the placement because it would have seem more logical to mount the turbo on the passenger side to reduce the exahust piping coming in front of the engine. Please don't take that as a critism, just wants your thoughts on that.
A question I get all the time is, how much time do you have in that? Have you kept a summation of the fab time for that turbo?
Old Nov 11, 2006 | 01:15 PM
  #64
Whistler's Avatar
I've got a bunch of it, I've been meaning to start a thread on it
Old Nov 11, 2006 | 11:32 PM
  #65
350SS's Avatar
Do it
Old Nov 12, 2006 | 12:01 AM
  #66
350SS's Avatar
I don't mind criticism or questions as long as it's constructive which it usually is around here. It all helps for future buildups. I couldn't really figure out how to put it on the passenger side since there isn't much to mount it off of except the cylinder head and I didn't like how I thought a bracket would turn out if I mounted it off of the head. I agree though if you could it would be better to do it that way or possibly to mount it really low and in the center to equalize the amount of piping from each bank and to keep heat away from things. Also with the exhaust manifolds forward and up instead of down like most of the f-body guys do, it made it more difficult to package, if you mount in the same direction it's running now, but on the passenger side you would have to come out of the turbine with a pretty tight bend which I wansn't crazy about although other guys make plenty of power with tight turns right out of their turbine so I'm not sure how much difference it will really make. One more thing I just thought of to is that even though the GT42 is a midframe turbo, the compressor side is pretty freakin big and was hard for me to get it mounted where it wouldn't be interfering with something (hood, pulleys, manifolds, etc) and still be able to place the outlet in a useful position. As far as heat goes, I think there will be more radiant heat coming from the pipes from the manifolds to the turbine as opposed to the downpipe, and that piping would be pretty similar even if mounted on the other side.
Time? It took a couple days to get the hot side piping setup the way I wanted it and another couple to weld everything together and clean it up. I can't tell you how long I had to stare at things though beforehand. One of my favorite quotes from a car mag I read is "Man if stuff got done by staring this thing would have been running months ago." Now that I think about it it took alot of hours to do other things involved with the turbo also...running the exhaust, mounting the intercooler, fabing the cold side piping. The more I think about it I have alot of time in the setup it could be 100 hrs or maybe 200 I really don't know to be honest.
Old Nov 19, 2006 | 08:51 PM
  #67
green28's Avatar
That is a nice setup you have going there. Can't wait to see the finished product. Someday I might get my project going, seeing this is motivation to get started.
Old Jan 26, 2007 | 12:07 PM
  #68
C for Chevelle's Avatar
updates?
Old Feb 13, 2007 | 09:05 PM
  #69
TuffSS's Avatar
Any updates???? I love Chevelles, having had two friends with 70 SS Chevelles back in the day. The 70-72's are super cool. While not a Chevelle, the last old muscle I've owned was a 72 Olds 442 with a 455. Unfortunately had to sell it a few years ago.
This project looks great.
I stumbled on this actually searching to see if anybody in here was running Hopster wheels. Along that subject I think they look great on your car, but I do think my choice mostly from habit would have been a more drag oriented sizing. However, having said that I certainly recognise this thing could be built to handle like a new car also. I probably would try to run a bigger diameter tire to fill the wheel well up more when viewing from the side. But man thats all nit picking stuff on my part. I just always have liked wheel wells filled with tire from both angles, atleast out back.
Car looks great.
Updates????
Old Feb 14, 2007 | 12:16 PM
  #70
chevelless502's Avatar
I am anxious to see it run as well, i was thinking a 5.3 swap for my 70 chevelle as well.
Andy
Old Feb 15, 2007 | 11:08 AM
  #71
350SS's Avatar
Hey guys...definitely got some updates, but I've been so busy with school and the motor swap on my truck that I haven't had time to post. I'll try to get together some video this weekend to post up. Should be worth the wait
Old Feb 15, 2007 | 01:16 PM
  #72
exodus's Avatar
I have been following this build since you have posted it up awhile ago, and am really excited to see where you are at now. I really have to tell you that I am sincere when I say that you have really done a fine job! I would really like to have the oppertunity sometime to see the car in person. Where are you located at?
Chris
Old Feb 16, 2007 | 12:45 PM
  #73
350SS's Avatar
Chris
Thanks for the encouragement...I've put alot of time into this thing so far so I'm itching to get it running right, but have other priorities right now. I'm in Las Vegas, NV btw
Max
Old Feb 16, 2007 | 06:57 PM
  #74
TuffSS's Avatar
I'm in Scottsdale, AZ. If I was a little closer, and well .......and didn't have my own stuff man I could see coming up to help out myself. This looks like an awesome car already.
Can't wait to see it progress. Gotta love Chevelles. I remember when they were all over the place. Heck, I remember when everything rollin around had chrome bumpers. Miss all the style. Like rolling art to me.
Keep us updated as you can. Sounds like theres several of us that are hooked, and anxious for a continued fix.
Old Feb 17, 2007 | 09:14 PM
  #75
exodus's Avatar
Look forward to hearing and seeing more on this car soon!
Old Mar 13, 2007 | 04:43 PM
  #76
domination's Avatar
Very nice looking. It seems like it will never get done but I think you'll be very happy with the GT42. I just clicked the link in your sig when you posted in the truck turbo build. Holy smokes we built the same kit almost!
Old Mar 13, 2007 | 05:25 PM
  #77
350SS's Avatar
Thanks for the compliment, I thought the same thing when I saw the buildup you're doing on the SS...real nice work. I've been following it on performancetrucks and over on turbomustangs I'd like to give a shot a doing full headers like you did, really ups the wow factor. Keep up the great work.
Old Mar 15, 2007 | 10:40 PM
  #78
THE_SUPRA's Avatar
intereesting.
wastegate??
good luck with that bad boy
Old Mar 15, 2007 | 10:43 PM
  #79
350SS's Avatar
Originally Posted by THE_SUPRA
intereesting.
wastegate??
wAsTeGaTe
Thanks, I'll need it
Old Mar 15, 2007 | 11:08 PM
  #80
THE_SUPRA's Avatar
**edit**
sorry, just saw the wg
