Bending header tubes: Need opinions
Old Feb 12, 2006 | 09:34 PM
70 LS1's Avatar
Conversion master
Default Bending header tubes: Need opinions
I picked up a set of LS1 Camaro headers for super cheap and they look like they are close to fitting. I need to move the passenger's side collector over towards the car's centerline a little bit. I need to do the same for the driver's side.
My thought was to heat up and bend the primaries near the head flange. A small bend here will move the collector over quite a bit. I was thinking of laying the header on a 6" diameter or so pipe. Then heat the primaries and apply pressure on both the collector and the head flange This should stretch the metal and allow it to bend without crimping.
What do you think?
Old Feb 12, 2006 | 09:54 PM
TT_Vert's Avatar
let me know how that works i may need to do this too
dave
Old Feb 12, 2006 | 10:03 PM
Stu Cool's Avatar
An alternative to bending them is to take a thin slice pie cut out of the underside of each pipe not to far from the flange, then push them in the needed amount, test fit to make sure, then weld the pie cut closed. Someone else posted that on the forum a month or two back and said they were successful.
Pat
Old Feb 12, 2006 | 10:59 PM
TT_Vert's Avatar
arent the ls1 headers cast iron?
Dave
Old Feb 13, 2006 | 12:19 AM
Stu Cool's Avatar
Dave
Since he typed headers, I assumed that he meant tube type headers for an LS1 Camaro as opposed to manifolds. I don't think bending cast iron manfolds would be possible. Actually the early manifolds (98-99?) were stainless steel and they could be modified and welded.
I could be mistaken.
Pat
Old Feb 13, 2006 | 09:01 AM
70 LS1's Avatar
Conversion master
The manifolds aren't stainless, they are cast steel. And yes mine are pacesetter long tube headers.
Old Feb 13, 2006 | 09:34 AM
67RSCamaroVette's Avatar
I clamped the flanges to the workbench, got a 3" pipe extension, heated it all the way around, and then put my bodyweight on it, and they bent fine. they had small stress marks, you cant bend it that much this way. only about 5 degrees. (from the slightly out to straight)
i didnt have a proper heating nozzle, also note block of wood.
olly
edit: above are pacesetter longtubes, too.
Old Feb 13, 2006 | 11:19 AM
G-Body's Avatar
sawzall wielding director
Another way to make sure that the tubes do not crimp would be to fill them with sand and then heat the tubes up and bend them.
Old Feb 13, 2006 | 12:04 PM
70 LS1's Avatar
Conversion master
I thought about the sand. Does that really work? Wouldn't you have to seal the sand in the tube to keep it from just running out?
Old Feb 13, 2006 | 06:41 PM
ls1_chevelle's Avatar
Well duh lol haha. I hear it works great too!
-Matt
Old Feb 13, 2006 | 08:49 PM
70 LS1's Avatar
Conversion master
I'll try that.
Old Feb 13, 2006 | 09:18 PM
yeah ive done that with a titanium header pipe for my dirtbike, works excellent. Use a 3" freeze plug from the plumbing dept at lowes for the collector, and 1 3/4" freeze plugs are avail from there or from autozone to seal the primaries. good luck, be sure to send pics!
olly
Old Feb 13, 2006 | 10:08 PM
70 LS1's Avatar
Conversion master
I assume you still heat the pipe with the sand?
Old Feb 13, 2006 | 10:20 PM
yup. sand's to keep it from collapsing, kinda like a mandrel bend.
Old Feb 13, 2006 | 10:39 PM
70 LS1's Avatar
Conversion master
Thanks guys. I'll post the results good or bad.
Old Feb 14, 2006 | 09:26 PM
cowboi89's Avatar
Default small world
I am putting a 6.0 in a 70 vette and I need headers now. Its amazing that your working on the 70 as well. If you have any more picture of what you did to the headers i would love them. wildduckf14@yahoo.com
Old Feb 14, 2006 | 09:27 PM
just heat it evenly and 2-3" from where you're bending, make it cherry red (i actually used 2 torches at a time to keep it hot) go slowly, and you'll be fine. good luck!
olly
