Clutch Line Size for Tilton Master
Datsun rocks! Especially with an LS1! The 280Z is just scarry fast, and the LS1 has so much torque that any gear at any speed is ok. I start in 1st and go to 2000 rpm then shift into 4th or 5th and just lug along. I never downshift to pass when I'm in 6th, I just hit it and it goes.
I wouldnt use -3 for the clutch, -4 is larger, and freer flowing due to its size. People do the "drill mod" for a reason.
Dont introduce that same restriction by using a hose that is too small diameter.
Dale, that is awesome. I can't wait to get mine fired up and ready to go. Once its mounted everything should be cake from there. I don't even know whats in store until I drive it. I've driven my friends F body with heads and cam and holy **** does that thing move... Now imagine that power in a 2600 lb car. Amazingly fast. -Alex
edit.....what the hell do I know..I just read in a thread below that the stock 4th gen MC is 3/4. I swear somewhere else I read 7/8".....
Sorry to muddy the subject...
Andrew
GatTagO. I think you got the 7/8 from the rx7 guy who posted about his projext. That what he is using. But stock is 3/4
I simply cut into and extended the -4 braided line with some -4 steel fittings, although I didnt actually use the factory MC.
