Well, i guess im an S10-LS1 guy now..
Nice to know we are not alone on this swap (91 w/5.3 4L60E)I know the feeling of doubt I bought mine as a winter truck I started undoing the hack work by the previous owner next thing I know it's down to the bare frame. Hey Great pics nice job on the frame Mods.I should have the 2.8 pulled this weekend and start on the frame notch next week.Anyone know anything about fly by wire throttle my motor's an 05 I'm thinking it might be best to convert back to a cable throttle plate ?
if you're going to run the 05 PCM, its easiest to retain the "throttle by wire" setup and just install the gaspedal with the sensor on it.
if you're going to swap harnesses to an Fbody one, aftermarket, or another PCM that uses the cable throttle, then change it.
although, im 90% sure the 05s use the later high res crank sensor.. so i think you're stuck with either the newer PCM, or an aftermarket controller.. if it was me, i would just mount the pedal.
remember, this isnt just throttle control, the PCM also uses the throttle blade to adjust for idle.. there is no IAC.
dont be scared of it, the factory did all the hard work.. all you need to worry about is mounting the pedal, and connecting a couple wires.. no big deal.
Originally Posted by BM4275
I bought the mounts, headers, and radiator from LS1performanceparts.com. The wiring harness and computor reprogram were done by current performance wiring.
The primaries are 1-3/4" with 3" collectors. They fit very well and I am very happy with them. Steve at LS1 Performance sometimes takes to long time to get things shipped. I think they are pretty busy. It took me about 90 days to get the headers but it was worth the wait.
holy ****! 90 days! well looks like i better order now. thanks for the info. they look like really nice headers. did you have to do anything with the steering shaft or mounts? or were they a direct bolt in?
Thanks MrDude I'm going to use the 05 pcm and have Current Perf do my wiring I have a pedal out of an H2 not sure if it is compatable My son works at Alps electronics in Mi he's trying to get me the part # for the correct Tahoe pedal.I found LS1 mounts for 59.95 at www.carshopinc.com
Another option on the pan is using a C6 Corvette pan (LS2 of course) It's a really shallow pan and only requires a small section taken out of the crossmember.
https://ls1tech.com/forums/showpost....&postcount=366
