So what's the scoop on Hooker headers?
Old Mar 21, 2006 | 12:45 PM
Glock36's Avatar
wow those are nice just ordered some for my 69
Old Mar 21, 2006 | 05:57 PM
wagonmaster's Avatar
Looks like they might fit my '39 Chevy sedan...??
Sweet!
Old Mar 23, 2006 | 04:46 PM
Steve68's Avatar
Olly I tried to send you pics but your account wont take them,
Old Mar 24, 2006 | 01:07 AM
67RSCamaroVette's Avatar
I'm still not positive, but I dunno if these'll fit with S&P style mounts... I got 2 1/2" clearance between rear of drivers-side head to firewall, a good deal more than the hooker mounts.. It's hard to tell if they'd still clear...
this is for the person that was wondering if truck accessories would clear- I think this shows it's a definate yes...
view from front to determine any height difference...
olly
Old Mar 24, 2006 | 06:10 AM
Steve68's Avatar
I'll have to measure the motor tonight I have ATS mounts
Old Mar 24, 2006 | 01:22 PM
ahowudoin's Avatar
Originally Posted by 68redcamaro
I ordered mine as soon as i got back from Sema were they had some on display. They came in at the end on January and i just installed them this weekend in my 1968 Camaro. They fit excellent i think. i have not found any problems yet. They come with collector, gaskets, bolts and O2 extension harness. Here are some pics.... if you need a speical shot just let me know.
What did you do for the oil pan?
Old Mar 25, 2006 | 12:44 AM
68Chevells1's Avatar
I have a set of Hooker mounts and a set of S & P style mounts. The Hooker mounts place the motor 1 3/16" further back and 3/8" higher.
Attached Thumbnails So what's the scoop on Hooker headers?-hooker_plates.jpg
Old Mar 25, 2006 | 01:10 AM
Welcome to the site, and thanks. Can anyone measure the critical points (like the steering box, control arms) to see if they'd clear with the above clearance difference? I'd like to get a set of these headers in the future, possibly, but I like the s&p mounts. The hooker mounts put it too far back for my liking.
olly
Old Mar 25, 2006 | 08:35 PM
68redcamaro's Avatar
I am using an S&P oil pan. There is plenty of room to drop the engine down more and forward.
The distance from the firewall to the driver head is 1 5/8" which is lees than an inch from the S&P mounts. Here is a close shot of the #5 header tube and streering box.... there would just be enough room. I think that would be the only clearence issue.
Old Mar 25, 2006 | 09:25 PM
SaweeeT! I think we've found the budget LT header for S&P, hooker, and ATS mounts.
Old Mar 26, 2006 | 08:38 AM
Steve68's Avatar
So the Hookers are it huh??
Old Mar 26, 2006 | 08:33 PM
  #32
pt67camarols1's Avatar
So,
What is the verdict here with S&P motor mount adapters? Which headers? I'm kind of confused.
68red Canmaro,
Can you also pls measure the clearence to steering box on that #5 tube. Please.
Thanks
Old Mar 26, 2006 | 09:46 PM
  #33
Glock36's Avatar
my hookers 2288-1hkr they look good until I went under, the pass, side collector is welded wrong it kicks out to the sub frame drivers side is perfect I called summit they just can't believe hooker would do that I have to call hooker tomorrow hopefully they will make it right
Old Mar 26, 2006 | 10:14 PM
  #34
pt67
I pulled the engine out this week end.... i should be putting it back in sometime this week. I will get a pic with distance on the #5 header tube.
Glock36
Sorry to here you got a bad set. I am sure Summit will take them back and send you another set. But i think that is a good idea to call Hooker and let them know you had a problem so they can find out what happened. Let us know what they say.
Terry
Old Mar 26, 2006 | 10:23 PM
  #35
68redcamaro,
Thank you. The reason I'm asking because I got the S&P mount /adapters and reading the posts that sits the engine 1" forward. So if you have more then 1" clearence between the #5 tube and steering box that would be sweet.
Old Mar 27, 2006 | 10:29 PM
  #36
Originally Posted by pt67camarols1
So,
68red Canmaro,
Thanks
I put a tape measure to the#5 tube and i don't think you could move the engine more than 3/4" forward and still be safe with the streering box. If you moved it 1 inch it might touch or it would be very close.
Old Mar 27, 2006 | 11:17 PM
  #37
a small dent could clear maybe, although the S&P mounts put it lower, don't they, does that adversely affect clearance? Or is that tube vertical?
Old Mar 28, 2006 | 12:06 AM
  #38
Stu Cool's Avatar
S&P makes an adapter plate the puts the motor one inch further back than their original. It's in their 2006 Catalog. Same price as the others.
Pat
Old Mar 28, 2006 | 08:37 AM
  #39
So what are they doing for a transmission mount? It wont bolt up in the same way if they moved it...?
Old Mar 28, 2006 | 08:55 AM
  #40
Glock36's Avatar
still dealing with hooker I spoke with the guy who designed these he sent some pics and basically said if yours look different send them back for another pair my mother is in the hospital so being there I haven't been able to take care of this(other than talking to the designer)
