LSx into '67-'69 Camaro, the basics
Old 10-14-2012, 11:52 PM
  #181
BlackLS1Camaro's Avatar
Anyone here happened to have notched the fbody pan themselves, or know a link to where the dimensions would be? I can weld aluminum just need to know what is necessary to trim to get it to fit in a 68 camaro.
Old 10-15-2012, 03:37 AM
  #182
LS1 pwrd NOVA's Avatar
Will a ctsv pan work also?
Old 10-15-2012, 12:54 PM
  #183
MisterD's Avatar
Originally Posted by LS1 pwrd NOVA
How close is it? Got a measurement amd a pic maybe? What headers or manifolds you using.
Pics are here. Let me know if you have any other questions, happy to help.
https://ls1tech.com/forums/16708248-post13.html
I plan on using Hooker Headers with these plates. Gmag has used them and everything clears fine.
Old 10-16-2012, 06:33 PM
  #184
Steve68's Avatar
look in the oil pan stickys, i shortened my pan,
Old 10-16-2012, 09:58 PM
  #185
No one? Any one?
Old 10-31-2012, 12:12 PM
  #186
windsma's Avatar
I couldnt find any pics for these headers installed so here you go.
Sanderson LS1 shorty/blockhugger clearances
steering lock to lock, no issues.
Iroc/Z28 steering box, 1in back LS1 conversion plates
V8RLS1-P $325.00 Non-Coated
Tube Size ............ 1½"
Collector Size ....... 2½"
LEFT RIGHT
DIM A ................. 2½" 2½"
DIM B ................. 10¼" 8¼"
DIM C ................ ---- ----
Weight (Lbs / Kg) . 15 / 6.8
Old 11-18-2012, 01:51 AM
  #187
88silvergt's Avatar
What adaptors fit the first gen power steering box for adapting the lines from the LS power steering pump? In my case I'm installing a 2001 5.3 truck motor into a 67 camaro. Thanks.
Old 12-30-2012, 08:12 PM
  #188
rollingmuscle's Avatar
Does anyone know of an affordable fuel tank with baffles, pump and sending unit that is a direct bolt in for a 69 Camaro?
Old 12-30-2012, 11:32 PM
  #189
Blevinator's Avatar
Thats an easy one
www.tanksinc.com
Old 12-31-2012, 01:08 AM
  #190
88silvergt's Avatar
Wow, 3 hours for his answer....
Old 12-31-2012, 07:25 AM
  #191
Steve68's Avatar
Check with DSE or Lee, the power steering company they sell the adapters your looking for.
Old 12-31-2012, 08:36 AM
  #192
gearhead67's Avatar
For the power steering, you might want to consider the third gen box upgrade at this time instead of getting adapters for the first gen box. The third gen box is a nice upgrade for relatively low cost. Plus you may not need the adapters as I think the 3rd gen box is metric also.
Old 12-31-2012, 08:50 AM
  #193
Steve68's Avatar
great idea, was'nt thinking this AM,
Old 01-01-2013, 09:25 AM
  #194
Thanks blevinator for the tanks inc site. I wasn't impressed with the spectra tanks and what I've read about them.
Old 01-01-2013, 10:13 AM
  #195
Blevinator's Avatar
No problem.
Finally, someone who actually charges what something is worth!
People think the "Corvette Tax" is so much should try building a first gen Camaro.
Also glad to see Tanks Inc offers the 400lph Walbro as part of their solutions.
Way to go Tanks Inc!
Old 01-01-2013, 07:15 PM
  #196
88silvergt's Avatar
I'm using the upgraded steering box from Chris Alston Chassisworks. Was guessing connections were same as stock. Will have to look that up. My hope was to put adapters on both the pump and steering box and run -6 lines. Prob push lock like the fuel lines if the pressure isnt too high. I just dropped the motor/trans in mine so its time for all the details like wiring install, P/S lines, fuel lines and coolant lines. Wish people in this area knew anything about swaps.
Old 01-01-2013, 08:30 PM
  #197
gearhead67's Avatar
Sorry can't help ya much with the Chassisworks box. FWIW when I did my 3rd gen box upgrade, I took the box and my first gen pressure hose to NAPA and was able to find adapters. I prefered that over guessing over the phone with somebody. You might also want to check out www.camaros.net to see if anyone there can help. I thought PS pressures were too high to use push lock or quick connect type connections, but I'm not sure.
Old 01-06-2013, 05:15 PM
  #198
Working with cable style throttle... anyone that went this route what was the best way to go? I seen earlier where you can use a V6 pedal. What about the cable, don't want to go too short.
Old 01-06-2013, 08:51 PM
  #199
lsx67's Avatar
Great project. One of my favorite cars
Old 03-20-2013, 11:41 AM
  #200
daddyzzs's Avatar
Anyone know of a way to use the factory 02 5.3 truck motor with 4l60e with a 67 camaro stock cluster. I'm wanting to try and use stock cluster or upgrade to electronic.
Quick Reply: LSx into '67-'69 Camaro, the basics
