LSx into '67-'69 Camaro, the basics
#81
Originally Posted by Rottluver
Best bet for staying smog legal with a transplant is to keep the factory emissions for the year of the car that the motor was taken out of as well as whatever may have been required for the year of car it is going in and you should be golden. Can always throw a turbo or a blower on there to get that extra boost (no pun intended) if you want more power. Or heads and a cam or pretty much anything else........![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#82
Originally Posted by 67Firebird455
My car was built in Lordstown Ohio back in the day, with a freakin 6 banger. Ugly *** gold and what not. I got the car with a 350 pontiac and 1976 455 heads (yielding somewhere around 7:1 LOL). I got this thing when I was 17 8 years ago (wow I'm gettin old). Car never had the original components, honestly I don't even know what happened to them. Was driving around with the 464ci "drag motor" in it and never ran into any trouble. As much as I'll drive it, cops won't bug me... I generally don't drive like ish unless a buzz bomb is thinkin they're badass and needs to be sown tail lights. The bird is already set up for drag, still need to weld in the 10pt moly cage, and do a few other things, but generally speaking, it's ready for big time power and some low ET's. Should be nice to get better than 5mpg and get the same amount of power! ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#83
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Don't know yet but I'll keep you posted..that's the set up I'm running on a 04 Goat motor in a 67. Headers are awesome looking! No O2 bungs..so you gotta run them in your slip-fit reducers, but the headers do come with the lengthened O2 harnesses.
#89
those are beautiful, im actually buying 1st gen headers and putting them in my 2nd gen. im gunna have to notch the frame right where the #1 primary comes out and starts its bend down
#90
Hello, first post, this is a great thread. We are planning an LS1 T56 swap into the wifes 67RS/SS (Clone, we aren't cutting up anything original). THank you very much for all the work you put into this thread. Do you have any pics of the finished project? Thoughts about the whole thing? How does it drive?
#91
like 67rsss asked, what are everybody's thoughts regarding the swap and finally driving their project?
and, i've only seen a couple posts about ls2's in this thread, and my question is, will an ls2 and ls2 harness and ecm work the same? thanks
#92
LS2 is the same as far as swapping goes, only minimal changes to the wiring.
driving the car is the most fun i've had in any vehicle. it hits 80mph in about five seconds with BFG drags, it's ridiculous. it handles and brakes great with ATS spindles and z06 brakes, worlds of difference from a stock Camaro.
#94
Originally Posted by leonpiper69
they fit great but almost 3 months to get (i hat when summit lies about how long stuff will take), what ya think?
![](https://ls1tech.com/forums/attachments/conversions-swaps/86801-lsx-into-67-69-camaro-basics-drvrhdr.jpg)
Can these be installed with the engine, steering box, and ATS pan installed, or does it need to be wiggled together as the engine gets dropped in?
#97
Originally Posted by CarlC
Great info guys.
#98
Originally Posted by 67RSCamaroVette
Radiator hoses for stock F-bod LS1 fans, (pretty much any motor mount, they've got to be trimmed a bit anyways..) are:
GoodYear part numbers..
61099 - (235) lower
61609 - (913) upper
Summit sells them too and a search for the part number gives a list of vehicles they woould fit.
The 61609 should fit GMC, Cadillac and Chevrolet. Modells are Sierra, Sierra XC, Sportvan, Vandura, Rally, Express, Savana, Brougham, Special, XT.
Engines: 4.3, 5.0, 5.7L
So that hose fits a lot of cars.
The lower hose 61609 fits Wrangler, Comanche and Cherokee from Jeep. Models are Sport, Sahara, SE, Laredo, Islander, Rio Grande and Pioneer. I think that is iwth 2.5L engines.
Years 87-93 and 95
You can search at Summit for # GTR-61609 and GTR-61099.
(Thanks for researching those, Jan!)
61099 - (235) lower
61609 - (913) upper
Years 87-93 and 95
Just to clarify some confusion here is the info I verified.
GY # 61609 Napa # 8244 Lower hose for LS1 rad / fans
1993 Jeep Wrangler 2.5L ( upper hose )
GY# 61099 Napa # 7902 Upper hose for LS1 rad / fans
1989 GMC Safari ( mini van ) 4.3L ( upper hose )
I used the Advance auto PN# E71306 for the LS1 upper hose $8 less than Napa
But the equivalent at Advance for the LS1 lower is to stiff to make the right bend. Use the Napa hose.
Both hoses will need to be trimmed to fit, my application is a 69 Camaro.
#100
Originally Posted by Rybar
Carl, I installed mine from underneath with the steering box installed. I did end up having a clearance issue with my rag joint and had to install a u-joint. You can see some pictures here: http://s34.photobucket.com/albums/d1...20head%20swap/
Thanks for the pics.
Is it just me or should they fit better than that? What motor adapter plates, motor mounts, and frame brackets do you have? Seems like very poor fitment unless SW has specific plate/mount/bracket needs.
