Is this mount setup strong enough?
Old Mar 22, 2006 | 10:41 PM
Slo_240sx's Avatar
Default Is this mount setup strong enough?
Ok here is my mount setup and what I plan to do. Car is a 93 Nissan 240sx, pictured here is my crossmember setup. I have S&P style mounts bolted to the block with SBC mounts. It will have a 1" sleeve inside the mount with a 1/2" hole drilled through for a long bolt. From there will be 2 1/2" x 1" bar tubing going down to a 3 1/2" x 3 1/2" base plate bolted to the crossmember. As you can see there is two slotted holes for bolts to go through. I was thinking about drilling holes into the baseplate I made and just use two bolts and nuts to bolt it to the crossmember. The base plate is 3/8 thick. Everything will be welded up I was just wondering if those 2 bolts (grade 8) will be strong enough to hold the torque of the LS1 without ripping the crossmember or just tearing something apart. Any other advise or suggestions is greatly appreciated!! Thanks guys!
Old Mar 22, 2006 | 11:17 PM
ls1_chevelle's Avatar
Looks plenty strong to me.
-Matt
Old Mar 23, 2006 | 01:49 AM
67RSCamaroVette's Avatar
If you're worried, either run some heavy washers, or make a matching plate for underneath the xmember, as well as locknuts.. Looks plenty strong to me, though. I wouldnt worry about it..
Old Mar 23, 2006 | 12:52 PM
MrDude_1's Avatar
id feel fine about driving around on that.
Old Mar 23, 2006 | 02:18 PM
owen v8litew8's Avatar
sounds like a good idea.
here are links to pics of Hinsons LS1 mounts for the 2nd Gen rx7... these are bolted to the subframe with 2 bolts on each mount, similar to what you are pondering. just make sure your welds are quality / have good penetration.
http://homepage.mac.com/owen_the_soy...toAlbum27.html
http://homepage.mac.com/owen_the_soy...toAlbum32.html
(ps, UPS just delivered my R33 Skyline subframe today... WOOOHOOO!)
