Gen 3 in '55 Studebaker PU - Camaro Subframe
1. I am assuming I will need to put a truck oil pan on this motor for the swap, I don't see anyway the stock oil pan will clear the front cross member. Will run 4L60E, will rework Camaro trans crossmember to work on 4L.
2. Any advise on motor mounts for this install? I am thinking S&P plates, with original Camaro motor mounts, on cross member and on engine?
3. Would like to get 350 +/- horsepower out of this motor, with minimum work on engine, want it to be a dependable driver. What mods?
4. Engine came with no computer or harness, what computer should I buy, and what harness? Thinking Painless?
Any help would be appreciated.
For the Harness, I am a big Speatech fan. Had him make a custom harness and reprogram my stock computer. The harness has only what I need and was built with custom lengths based on where I was placing the computer. He also lengthened the O2 connecters to hook up below my headers.
With that big engine bay, you should have plenty of options for exhaust.
Hope that helps, keep us posted on the project, we like pictures!
Pat
Thanks for the post, I previously saw your posts and looked at your swap page, looks like a too cool Stude. I like the fact that you are documenting the swap for everyone to see.
I'm having trouble finding the Hooker motor plates I've seen mentioned. I'd like to check them out. I'll probably go with aluminum plates, to match the rest of the motor, I've seen the steel plates on ebay. I also have been checking out the Speartech stuff, it looks like they know what they're doing, so I'll be sure to give them a shot.
Again, thanks for the info, and I'll be sure to keep an eye on your swap.
Keith
Andy1
Any further feedback or information would be greatly appreciated.
I stopped by the Chevrolet dealer a few minutes ago, and the kid behind the parts counter says he has a brand new LS1 cam that he would sell for $100. Any idea what an LS1 cam would do to a 5.3 liter? I want a little more HP, but want driveability and dependability.
Again, thanks for any help.
http://www.southernperformancesystem...ec5300LH6.html
Pat
http://media.gm.com/division/2005_pr...33-LM7-L59.doc
You know, I didn't think of the LH6 possibility. Here's yet more info:
http://media.gm.com/division/2005_pr...specs.html#lh6
Good luck,
Andy1
