Chevelle Fuel Tank
Old Jul 19, 2010 | 07:16 PM
  #41
the450r's Avatar
do u have any measurements on the hole you cut or the box u built? i dont know where to start cutting and id like to know if my speaker box is still going to fit in there.
Old Jul 19, 2010 | 07:55 PM
  #42
bczee's Avatar
If your referring to a using a Impala tank and how much it will need. a 12x12 should do it.
Old Aug 29, 2011 | 05:49 AM
  #43
Aceshigh's Avatar
Just to update this thread.....
On my B-body tank install into my 1970 442 I used this Gates 1 3/4" flexible fuel line to
connect the impala fill tube to the tank. The stock nitrile hose on the tank isn't flexible at all.
I picked mine up @ O'Reilly's.
First I tried to have the impala fuel filler neck heated and bent by a muffler shop but installing
it onto the tank, then putting the tank in with my own bent tank straps proved near impossible.
This made it 100x easier since it's more flexible and gives you more room to maneuver.
http://www.oreillyauto.com/site/c/de...0065&ppt=C0075
Old Aug 29, 2011 | 06:32 AM
  #44
chuckd71's Avatar
I did something similar on my neck (not a b body, but same concept I think) - https://ls1tech.com/forums/15268858-post214.html
Oreilly has two (or more?) different kinds of tube that size, one is really stiff with metal bands kind of built inside it and the other is still stiff but more pliable and I believe all rubber (or whatever it is).
Old Aug 29, 2011 | 09:03 AM
  #45
71Fakes's Avatar
Another udpate for those interested in the future:
I used a new factory tank + the Competition Engineering sump + external fuel pump.
The car has been running this way now for 5+ years without issue. I have been to countless autocrosses, a number of open track events, and some drag strip passes. Never a problem with fuel supply until I am <1/8 of a tank. The sump will hold enough fuel (with the hole-drill baffles per Comp's directions) to make it through any long sweeper, etc.
I prefered this route since I didn't need to cut a hole in the trunk floor or cut the rear frame rails. I certainly see the appeal of the Impala tank system though!
Old Aug 29, 2011 | 10:11 AM
  #46
SUPERBOOST's Avatar
What external pump did you use and is it noisy?
Old Aug 29, 2011 | 03:37 PM
  #47
71Fakes's Avatar
I used an Aeromotive pump & filters. Not noisy at all. Just mounted with some rubber isolators.
Old Aug 29, 2011 | 05:55 PM
  #48
grant454's Avatar
I used a 95 impala and put the fuel pump assembly out of my 04 gto in the tank . The filter pump and regulater are in one unit so u only need one fuel line
