Fueling the 68 c-10
Old Apr 14, 2006 | 10:28 PM
oscareltemblo's Avatar
Default Fueling the 68 c-10
What kind of external fuel pump can you guys recomend to use with my in-cab fuel tank in my 68 c-10 to supply fuel to a ls 6.0 thanks.
Old Apr 14, 2006 | 11:27 PM
anyone.
Old Apr 14, 2006 | 11:33 PM
67RSCamaroVette's Avatar
: wabro 255lph ... for simple effective and cheap, aeromotive if you've got big plans. patience, grasshopper. sometimes it takes more than an hour for a reply.
like this..
http://shop.store.yahoo.com/fuel-pumps/500.html
I ordered one on ebay just yesterday.. 120 shipped.
olly
Old Apr 14, 2006 | 11:36 PM
Thanks it's one of my loose ends to accomplish the swap.
Old Apr 15, 2006 | 01:50 AM
IOwnCalculus's Avatar
That's the pump fueling my '70 GMC. Works great.
Old Apr 16, 2006 | 10:58 PM
thanx guys...
Old Apr 17, 2006 | 10:34 AM
Kenova's Avatar
Good Lord son!!! Moving that damn tank out of the cab should have been the first thing you did!!
Ken
Old Apr 18, 2006 | 12:28 AM
I know I'm going to do it I just don't know where the new one is going to go I'm thinking the rear but, I really want to try the side like the newer trucks .
Old Apr 18, 2006 | 01:27 AM
look at shifty's page. He's got his hidden under the bed, and the filler underneath the reflector or something. Unless third degree burns and death, as well as the loss of your truck, are enjoyable to you, GET IT OUT!. My uncle had to bail out of his '67 on the freeway, when the battery under his seat ignited the seat, lighting the tank on fire. very very dangerous.
Good opportunity to smooth out that part of the cab, while you're at it.
olly
Old Apr 18, 2006 | 10:37 AM
kwkenuf's Avatar
Here's mine in my 65. It's a Blazer poly tank.... no room for it anywhere else but the rear.
Old Apr 20, 2006 | 05:18 PM
Ken
Mine's still in the cab. First thing I did was get rid of the four-wheel drums!
Old Apr 20, 2006 | 08:25 PM
I'm getting a custom tank from a guy in michigan it holds only 11 gals. and is rear mounted I like it cause it doesn't hang low the bad thing is that I'll have to fuel often.
Old Apr 21, 2006 | 03:40 AM
AceHaag's Avatar
gas tank
check this out this might be what your looking for.
Old Apr 21, 2006 | 09:22 PM
Thanks ace that's the setup I was looking for but, I found one from a guy in Michigan that's more tucked in.
Old Apr 28, 2006 | 07:30 PM
Here's the pump I'am going with "Walbro GSL392 250 LPH In-Line Fuel Pump" is this what I should use? I found it for $109.00 locally is that a good price?
