Where do you install youre oil pressure sensor?
Originally Posted by mitchntx
If you look just below the cam on the throttle body, there is a flat, horizontal place on the water pump. Drill and tap that to 1/8 NPT and install the sensor there.
It will give you the temp of the water as it exits the block, a better, over-all engine temperature reading ...
