Starting issue no spark no fuel
srun
the pcm is a 99 and the harness is out of a camero of the same year
the pcm doesn't control the fuel pumps in my car. also the wiring is mostley the same as when i got it out of the other car. does anyone have diragram for the fuel injector connector and whats suppose to be hot also the coil packs. i'll go over the wiring again tonight. I'm sure the crank and cam sensor are working now. I see rpm when i bump the starter.
1) 2 power feeds, 1 switched off the PCM
That switched should power the coil to close the relay.
2)1 constant ground on the other side of the coil (control circuit)
4)power feed to the pump when the relay is closed.
On my car, the old setup was a ground to close the relay. I had to cut it and constant ground it then cut the control circuit power feed that was activated by the PCM.
Once you have fuel pressure I would then worry about the other problems. Jump 12v to the relay to see of the pump kicks, if not then your other relay wiring is wrong. If it does activate however then your PCM isn't outputting the 12v power feed to the relay and you either have a bad power feed (probably constant 12v orange wire) or a bad ground.
Look on your scanner again and see you have a RPM signal on the scanner. Yes the PCM does output a tach signal, but that is after the PCM converts it from the input the crank signal give the PCM. If you have no crank signal input from the sensor then your PCM will not fire the coils or the injectors. Vats also disables the injector pulse width after 2 seconds when it does not recongnize a passlock key input from the BCM. Figure out fuel then let us know. -Alex
assuming i connect with the scanner, i would then watch the "RPM" gauge in the scanner and crank the engine.
if the crank sensor is on right, working, then you should see some RPM..... if it doesnt, the PCM does not realize the motor is turning, it does not fire spark and it does not fire the injectors.
also, the injectors and coils are powered off of two fuses, one for each bank.. check thoes.
thoes two things would be where id start.
sounds like the ECM doesn't know the motor is running/cranking. he has pressure at the rails just the injectors aren't firing.
