C5 dash in a C4 vette?
Here is a shot of the C5 dash before cutting (note the gauge bezel area protruding too far out).
Here is a shot of the dash cut to move forward approx. 4 inches (I need to cut 1 mone inch off but I have to get my gauge cluster first to ensure nothing will hit).
Shot of the center after cutting (note the heater vent lines up properly)
Here is a center console shot (note, lines up perfectly with the trans tunnel)
I'll keep you all updated on the progress. For those of you that don't know what I'm doing I have an 84 corvette that I'm putting a built LS1 with AFR's, phat cam, long tubes, and dual exhaust on. I bought a Dana 44 rotor to rotor setup with 4.11's in it so I could use the 50mm style offset (I'll need more options for running 10-11" wide rims to plant my 420-440 rwhp
). Till next time....Scott
