05 colorado ls1 swap
How can so many be so wrong?
Why would I tell anyone that my harness is done and not tested when I know that not to be true you fu@#ing liar.
I am sure you lost your wiring guy because you jacked him around as well. I really think you should go into fictional writing, because the performance automotive gig is certainly not your bag.
My wife let me spend nearly 6k on an ls2. It looks like you are selling a supposed built ls2 on ebay for 5,300.00. How is that saving any money when your engine supposedly has more power? Why don't you tell everyone that you bought an engine from me on ebay, and wanted to trade me for one of your gunna get you sued pieces of ****. Why don't you also tell them that you never ended up paying me for that engine there con man.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8072721295
Thanks for this little bull **** tirade. I can assure you that this will do nothing but strengthen my resolve. I am putting together a list of people that have been screwed by you. I will then forward these names to the AZ state attorney generals office. By the way steve, how is that lawsuit coming along?
This is great. I cant believe steve posted! He is always too busy to answer the phone (after you paid for your order)- but he has time to sign up for the forum. Ive tried to call the bbb in chandler, but the would/could not do anything for me. I think we should start a new thread somewere else so everyone who has delt with him can post.
I got the cts-v power steering pump and alternator installed. The alternator was straight forward while the power steering was a little tricky. The cts-v power steering pump uses a push in high pressure line because the line is very close to the pulley. I wanted to run -6 fittings because they are dependable and easy to find. I had a bulkhead fitting turned down so that it could be pressed into the bored oem fitting. It was then pre heated to 350 degrees and tig welded.
The power steering pump on the original 3.5 engine is on the pasenger side, so the lines out of the rack were bent in that direction. I cut the lines about 3/4 " away from the plate that retains them in the rack. I had two -6 fittings machined so I could press fit them onto those lines as well.
I used the corvette ac compressor so I didn't completely waste my money. I am looking for a manifold that will work with this set up, but I am not having any luck. If anyone knows of a place that does custom ac fittings, let me know.
I will post some more pics when the truck gets back to the shop.
