Installed Fast 90 and Ls2 TB today...
Its a tad bit annoying, but Im going to have to retune the car yet again anyway, becuase Im sure this mod threw off my VE table and MAF again.
Have you done any logging or tuning yet????
This is part of my total heads cam install just done a couple months later...There is the internal content...orangepeel.
A couple of things for you to look in to:
-Did you remember to reset the LTFTs after the install (still using old trends)?
-Have you adjusted your ETC Scaler values yet?
-I would go ahead (you probably are) and true-up the VE table in SD mode...
-How are you handling the MAF... are you going to recalibrate after SD tuning the VE??
I am getting mine Friday, will be keeping an eye on your progress...
Be prepared for some loss of response at part throttle... I found out it is the tradeoff because of a 30% larger throttle body. Oh well, I can live with it depending on how much power it adds at WOT.
Also there is no connection on the Ls2 TB to connect the valvecover breather hose from the passenger valvecover...??? Still wondering about that issue.
