Best way to clean block
Old May 23, 2006 | 10:21 PM
chickenman97's Avatar
Default Best way to clean block
Guys
I have the motor pulled out and the wireing harness taken off. What is the best way to clean the motor that won't hurt any of the electrial stuff??
Thanks,Davis
Old May 23, 2006 | 10:24 PM
THE LAST Z's Avatar
engine degreaser. let it soak, the scrub it with a brush, then rinse.
Old May 23, 2006 | 10:28 PM
G-Body's Avatar
sawzall wielding director
I used a pressure washer, dishsoap, and kerosene to clean mine. I knew that the kerosene wouldn`t harm the wiring/electronics but I didn`t know what engine cleaners would do. Anyway I soaked it in kerosene for 15 minutes, pressure washed it off, soaked it in dishsoap for a while and pressure washed that off. It worked very well.
Old May 24, 2006 | 01:01 AM
67RSCamaroVette's Avatar
1. degreaser, pressure wash...
2. oven cleaner on tough grime, sit 1 minute
3. pressure wash
3. blast anything else off with brake/carb cleaner
4. bead-blast any stubborn spots/corrosion.
worked for me (not for block, but for waterpump, etc...
Old May 24, 2006 | 07:43 AM
rnp.ent's Avatar
it may sound silly but scrubbing bubbles works great spray it on let it soak rinse off works great for engine detail also.....
after it dries spray everything with crc lube when that dries everything looks new...
Old May 24, 2006 | 08:21 AM
Thanks guys good info. I'll try to get the aluminum as clean as possible.
Old May 24, 2006 | 11:26 AM
Oscar Will's Avatar
We have replaced a multitude of tps and other sensors that were killed by pressure washers, just be careful where you aim those things.....most develop over 2000 psi and will force water into places you thought were "watertight".
Old May 25, 2006 | 05:09 PM
72ChevelleConv.LS1's Avatar
I jus used simple green on one I am working on with a brush. Man It sure worked great. This stuff works the same on floors too.
Old May 25, 2006 | 09:19 PM
very good point. I've accidentally removed all the grease from a wheel bearing with a pressure washer. be careful. an engine block is no prob tho.
