Is this ok?
Old May 26, 2006 | 11:55 AM
xXxSilveradoxXx's Avatar
Default Is this ok?
Does my motor look ok? I pulled the heads and it looks a little chared. This is the first time I have pulled apart an LS1.
Attached Thumbnails Is this ok?-jkhgjk.jpg   Is this ok?-dfsgsd.jpg   Is this ok?-jghiu.jpg
Old May 26, 2006 | 12:01 PM
stealth71's Avatar
Might want to post this in Internal Engine section. How many miles are on it? Does look funny.
Old May 26, 2006 | 01:59 PM
bczee's Avatar
What kind of motor oil have you been using..? brand of gas ?
I would not be happy with what I see on the heads/valve's.. that coloration can't be anything good. There is a lot of carbon build up on the piston also..
Did u do a leak down or compression test before taking it apart ?
Old May 26, 2006 | 03:32 PM
custom 68's Avatar
I am no expert but it looks like the oil on/in the heads looks like it got hot, almost burnt? maybe it is just the mileage.
Old May 26, 2006 | 05:29 PM
pist0lpete's Avatar
Mine looked somewhat similar to that but not nearly is a dirty. However mine was a 20,000 mile engine but it did have a couple of rings that didn't seat correctly.
Old May 26, 2006 | 07:22 PM
digitalsolo's Avatar
Looks like cheap gas and a cheap low detergent oil to me.
Old May 26, 2006 | 07:31 PM
Project GatTagO's Avatar
Looks like they never changed the oil.
Andrew
