V8 in yota pickup
cam, heads, intake
so yes, do a search for 5.3 for some examples
advanced adapters makes trans to t-case adapters
http://advanceadapters.dirxion.com/Main.asp
I am also doing a swap in my very cheap thrills Toyota 2wd. I was lucky enough to find a LS6 long block with a Victor Jr. intake and a Holley 750 carb. I am running a 200R with a 3000 stall lockup. Lots of parts available out there. The 8.8 rear end out of an Explorer is almost a direct bolt in for the rear. These little trucks are only about 2400# so they can really fly with a basically stock motor. Good luck with your project. Mac
carbed v8's have been done many times, i'm sure if you looked on a 4x4 toyota site you could find all the required info on what is required for many different setups.
with the all iron 400, 700r4, transfer case, 4WD 15x10 wheels, 35x12.5 tires, his truck weighs in at 3600 lbs. that was on two scales. I don't see how you could get them down to 2400 lbs. maybe the all iron engine, 4wd, and big wheels/tires add that much weight?
If you come in at your 2400 lb weight goal you SHOULD get better gas mileage than a automatic F-body. probably well over 20mpg on the highway.
however a t56 would be cool to see!
