Turbo Nova running video
Old May 29, 2006 | 09:02 PM
pwrtrip75's Avatar
Default Turbo Nova running video
http://videos.streetfire.net/video/1...21db93952f.htm
Its not tuned yet so I have no numbers or times.
Old May 29, 2006 | 09:28 PM
BringIt10s's Avatar
Wow Nice Work.
Looks like a real sleeper except for the loud fuel pump and after you pop the hood.
What is that pipe hanging down in the front?
Old May 30, 2006 | 12:00 AM
Mavmavv's Avatar
Damn, which way to the airport? Thats the loudest fuel pump ive ever heard
I love it. Plans on suspension? Dropping the front a tad? Or keeping that stocker exterior look?
Old May 30, 2006 | 06:05 AM
1dirtyZ's Avatar
put some hubcaps on it and go feed!!!!
Old May 30, 2006 | 09:30 AM
lilbuddy1587's Avatar
Nice vid! I just stumbled upon this on streetgay actually! Sounds good man, just hate the damn buzzing of the fuel pump
Old May 30, 2006 | 10:11 AM
diognes56's Avatar
David
Old May 30, 2006 | 02:28 PM
pwrtrip75's Avatar
right now it still has the big block springs in it, yes it sits too high...I will eventually change them. Suspension wise...it already has a 4 link setup w/ 15" wide tires on it, its kinda hard to see I didnt get a good shot of that.
Fuel pump is an aeromotive one, very loud, Im going to make a aluminum tank and put a couple walbros in it eventually also.
The metal tube that I think your talking about is my tranny cooler, I just wired (rigged) it up temp to see if the car would make it around the block. Its actually mounted out of site now.
Old May 30, 2006 | 02:48 PM
Steve68's Avatar
Nice APU (aux pwr unit) you have there, it is loud but cool,
Old May 31, 2006 | 12:04 PM
NemeSS's Avatar
so how is that gt45 spoolin?
how much psi are u seeing/running?
what was the ci again?
any videos of it runnin down the street
cool car
Old May 31, 2006 | 03:41 PM
pwrtrip75's Avatar
I had it out once messin with it, full boost is at 4000 rpms, im running 14psi. But the hose blew off imediatly. I figured it wouldnt spool up lower since i plan on building a bigger shortblock later, but its better than I expected. I have more tuning to do and a sticky ignition switch to fix yet. It is a 5.3L 323ci. Has 6L heads on it which brings compression to 8.6:1
