Temp Gauge
Old Jun 1, 2006 | 08:03 PM
ramair21's Avatar
Default Temp Gauge
I just fot back from the stealership to get an 98 LS1 temp sending unit for my stock 89 temp gauge? Did i get the right one? Cause the sensor has 3 prongs inside and according to the diagram it shows one wire??
Old Jun 1, 2006 | 08:28 PM
ramair21's Avatar
Edit: My car is an 89 camaro RS if that helps any LOL
Old Jun 1, 2006 | 10:46 PM
ramair21's Avatar
So is there anyone with the answer im looking for?? i really need to know before i drop the engine in
Old Jun 1, 2006 | 10:56 PM
ss1129's Avatar
Sometimes for the person that has the answer to come along, it may take more than a few hours.
Old Jun 1, 2006 | 11:19 PM
1bdbrd's Avatar
im not sure about 3rd gens but ive been told and read several places that the 98 sensor is what you need for the lt1-ls1 swap. i would assume it would work for your camaro as well..
Old Jun 1, 2006 | 11:41 PM
G-Body's Avatar
sawzall wielding director
Yes it will work, I don`t know if the gauge will be perfectly accurate but I have heard it is very close. Wire pin A brown wire to ground, pin B yellow to the computer, and pin C dark green is the feed for your factory gauge.
Old Jun 2, 2006 | 12:31 AM
ramair21's Avatar
Sorry for being in such in a hurry Ok, since i just need the gauge to work i just need to use the brown and dark green to make it work. COO, now where could i get a connector to plug into there with pig tales?
Old Jun 2, 2006 | 12:34 AM
ramair21's Avatar
I think i found the connector, is this the correct one for the sensor?
