It Lives
Old Jun 2, 2006 | 11:28 AM
Schitzo's Avatar
Default It Lives
Got my PCM this morning and fired the beast 15minutes later. Fuel pump primed, I hit it and the engine fired right up....no stalling no puking....no hesitation.....It has open manifold right now and sounds pretty loud in my tiny garage.
The oil pressure came right up within 4seconds. I have not let idle for more than 10 seconds though
My only concern is the idle RPM.......it is really high. I don't have a tach hooked up but I can tell it is prolly +1500....For that reason I did not let it idle long.
Is this normal....should I grow some ballz and let it idle alittle longer? Could this be because the PCM is learning? Did your guys first start up behave in a similar way?
Thanks to all the guys who have helped me....I could not do it without you guys.
CHeers
Old Jun 2, 2006 | 11:39 AM
Schitzo's Avatar
idiot update
I spent most of last night double checking and triple checking everything.....I thought I got it all.......turns out all my vacuum ports are open.....I forgot to cap those...
I'll grab some caps and see if that calm her down.
Old Jun 2, 2006 | 11:48 AM
Jhankinson's Avatar
on mine the first time I fired it up....it went through warmup at close to 1250...then settles down to about 850. After about 10 times of that....and now 2 1 mile test drives...it has settled down to about 1100 at cold start...and about 800 after warm up cycle. After you cap all the vaccuum ports...it should be just fine.
J-
Old Jun 2, 2006 | 12:39 PM
Schitzo's Avatar
J-
yap.......that did it....
It is on jack stands right now......I put it in first...let the clutch out slightly and the wheels spun.......
Old Jun 2, 2006 | 12:59 PM
nitrovette's Avatar
congrats,mine idled around 1200 or so cold then down to 800.
Old Jun 2, 2006 | 04:47 PM
Stu Cool's Avatar
Wow! Great news, heres to ya Been wondering when this news would show up.
Like the others said mine starts up about 11-1200 then settles down around 800. I know you gotta be pumped and can't wait to be . After making sure everything was working on mine, I just drove it to the muffler shop, no problems.
Congratulations
Pat
Old Jun 2, 2006 | 05:19 PM
Schitzo's Avatar
Pat
just got from the muffler shop.....this thing sounds great and pulls hard.....I was tempted to beat on it but I parked it and will check everything again to make sure all is well.
Old Jun 2, 2006 | 06:36 PM
LSxChevelle's Avatar
Very nice job! If I could only talk my dad into doing his 73 Z28 RS w/ a LSx engine...
Jason
Old Jun 2, 2006 | 09:04 PM
67RSCamaroVette's Avatar
congrats! mine's being painted on Tuesday then I hope to fire mine up too Everyone else getting their conversions running is encouragement to finish mine. Now post pics/vid!
olly
