4L80e GURU's I have a question for you..
Well, I broke down and ordered the Line Relocation Kit from Sonnax, (retrofits the newer case style to the older fluid line setup where both lines are up front) I dont need most of it, but it does have the ever so important fitting. If anyone has a connection at Sonnax, get them to sell just the fitting !!
![](http://www.turbols6.com/albums/4L80e-Trans/abk.jpg)
if you didnt need the tube on the end, you could order the fittings from ATI Performance, their #6ANx1/4-18 straight thread, screw right in-only trouble on the 4l80e you need that little piece of tube-i experimented drilling one of the ATI fittings out and pressing a piece of 3/8 tubing in it, with a little locktite-only worry would be if it slipped out
another thought was to take the stock fitting, mill off part of the head, then weld a #6 steel male bung on it-the closer you keep the fitting to the trans, the more clearance you would have
if anyone makes some, i would be interested in one
