2003 Silverado air intake temp sensor part#?
Old Jun 12, 2006 | 10:55 PM
ls1_chevelle's Avatar
Default 2003 Silverado air intake temp sensor part#?
I'm having no luck at GM finding this sensor. The one that goes on the air intake itself.. Like the title its the air intake temp sensor.
On Gm parts direct.... I found one part number but it says it includes the MAF? Which I don't need lol.
Any help would be much appreciated.
-Matt
Old Jun 12, 2006 | 11:13 PM
G-Body's Avatar
sawzall wielding director
On my 2001 tahoe 5.3L the IAT sensor and the MAF are all one part. How many wires does your MAF have? Mine has 5.
Old Jun 12, 2006 | 11:16 PM
Schitzo's Avatar
i believe they are the same out of any later model GM cars. I got mine out of some 2000 oldmobile....works fine.....don't know the part # though
Old Jun 12, 2006 | 11:31 PM
Mines 5 wire aswell but I have a 2 wire plug on the same wire loom that is labled air intake temp...?
-Matt
Old Jun 12, 2006 | 11:33 PM
G-Body's Avatar
What color plug and wires, I believe I have the same plug on my harness (its about a foot down the harness where it branches right), but that plug is for the coolant level sensor.
Old Jun 12, 2006 | 11:38 PM
G-Body's Avatar
My MAF has wires pink, yellow, tan, black and black with white trace. The coolant level switch is a white plug with a light green wire and a black wire. if your plug has those wires check to see if the light green wire goes to pin 30 of the blue PCM connector, if it does then it is definently for the low coolant level switch. The black wire is a ground for the sensor.
Old Jun 13, 2006 | 01:18 PM
Green and Black if I remember right... Coolant level... Where the heck does that sensor go? I could have sworn it was intake temp labled before it got ripped off.
-Matt
Old Jun 13, 2006 | 11:30 PM
G-Body's Avatar
The coolant level sensor goes in the radiator to warn you if the coolant level gets too low. It is not needed in a conversion, and is really just a convenience feature for people who would not check their coolant level regularly. In my conversion I just abandoned the wires, it would be kinda neat to have it hooked up but I don`t really see the need and have not been that bored yet. Mabey someday I will put a sensor in and hook it up.
