Cj7 Finally On It's Way
Originally Posted by JeepinBash
man seein a third gen motor in a jeep really gets me pumped. i'm about to drop 425 horse ls1 into my lil' TJ in a few months and seeing posts like this one makes me feel at ease because from right here it seems like a massive project but i know in the end all the hard work will be well worth it.
Thanks
well 425 might be a bit optimistic. i mean there are guys on the board here, from what i can tell, that get about 400 to the wheels with a similarly built motor. so maybe 425 at the crank?? i dont know just a guess.
Originally Posted by jeepinpete
What kind of gas mileage are you getting Power On, assuming you ever get out of the pedal
Thanks
Originally Posted by POWER ON
Still on my first full tank. Just enjoying it and haven't calculated it yet. Seems like it's a engine pushing it's self. Don't take much peddle to move it, like the RPM is about 1200 most of the time. On the other hand, like I said step it and the tires are spinning!
Thanks
Thanks
What size tires, gears do you have? have any external pics of the Jeep?
Originally Posted by WhiteStripes
Haha, there's no road or trail that thing won't be able to handle now. Great job.
your right about the road part, but uhhhhh not quite on the trail part.
dont get me wrong here i like the guys jeep but 31's wont get you too far off the paved roads.
especially if its not locked.
ummm.......
Thanks
I plan on putting a LS1 into my 1986 CJ-7...I intend to use a NV4500 5 speed behind it and the stock Dana 300 behind that. Your conversion looks real nice (your wife must love it). Where did you get the engine and how much did you pay for it? I know you have probably answered this question already but as you can see by my number of posts I am new to this website. How tricky was the wiring? Did you have someone re-program the computer? Finally did you have to change the fuel rails? I read somewhere that these motors were set up to use only one fuel line (what about the return??) Thanks in advance and once again NICE JOB!!
Thanks
#33
That jeep looks sweet. Do you know if AA sells a kit to adapt a 4L80E? I have a new 7.0L that I just got in and I have two trans to to choose from 4L60E is the other. As far as the transfer case, did you use the GMs or the JEEPs? Sorry for all the questions, Im knew to the Jeep world. Thank you for your time.
#35
That looks great. The truck engines are a snakes nest of wires, aren't they.What fans are those, model number please. How thick at the fattest point? I need a set like that for my S10 Blazer.They look pretty thin. Just got back from the Chevy Dealer in Town, The service manager asked me a **** load of questions while he printed me out a 1/4 inch thick stack of shematics and pinouts.Told me to bring it by when done. Also said somebody in my towns putting an LS1 in an old Nova. Anybody here live in Dover Arkansas? Hopefully this weekend will get the wiring done and my exhaust on. Glad to see its running good.
#36
#37
Thanks
#38
Power on, your JEEP looks AWSOME I'am doing same converson was wondering what drive shaft you used ? my driveshaft rubs the trans. pan I have 4l60e trans with "deep" pan aprox. 2 inchs deep have been told there is a trans pan that is shallower . Not sure if this will help ? I'am running d-300 t-case. Do not want to run driveshaft with carrier bearing if do'nt have to. Thank you for your help HUMJ7.
#39
Thanks
#40
POWER ON, Do you know manufacturer and part# for the nice stanlless oil presure line you have ? Same ? about fitting for water temp gauge in the block . The tapped hole in the head is 12mm I believe . Temp sending unit is 1/4 pipe thread.
