pics of my 69 camaro blackwidow in progress
69 ss camaro with ls1, tko 600 tranny, 355 rear body mods no drip rail, door locks,handles,sidemarkers, flush mount windows, caprice gas tank, hidden vw wiper motor,honda e-brake on tranny tunnel, g-west upper a-arms, hotchkis springs and front bar, koni shocks,stainlessworks headers,yurnkey harness. got the 99 ls1 with 1400 miles on it for 2500, did not want to pass that up. when i took the pan of to get the mod done, it still had the the numbers in marker inside the pan and factory oil filter mike
http://s76.photobucket.com/albums/j16/69blackwidow/
stealth its a 90 some vw jetta wiper motor,i think its a 98 jetta got it off e-bay for $4.00, ship was $12.00 lol, put it on the fire wall, under the driver fender where the blower motor is on the pass side. took the arm of the stock motor put it on the jetta motor. cut the ball end off the wiper arm and welded some round tube to reach the new lo cal, welded the ball end back on. hooked it up to a batt charger to get the set up right. work good mike
yes the impala tank is the same. i made access pan in my trunk to get at the fuel pump with out droping the tank. i would of had to make a hole in the trunk anyway. the pump mounting plate and lines stick up to much. thats a great deal on that hydroboost mike
rabar, they are tight with the one tube with the one bolt on top of the steering box, but i can put both headers on from up top no problems, as far as the s&p mounts go, they are nice but had problems with motor mounts. the stock crap rubber ones worked but the energy and prothane ones would not work with out mod. i welded the frame mount holes shut and redrilled them, now they work fine. leon may not use covers, but if i do will fab some up myself
