What is everyone doing for power steering hoses?
Pat
They are nice and clean, work perfectly
Not to highjack the thread.But,do you still use the piece that is a water jacket to cool the power steering fluid that fits in the radiator hose???
Thanks,David
I will use it since my car will see some hard driving.
Jan
Thanks,David
https://ls1tech.com/forums/conversions-swaps/532488-my-ls1-69-z-28-a.html
Under the intake hose you'll see a aluminum tube with a flange on. That is the PS oilcooler. Some of the F-bodies has it, mine came from an 2002 SS. Its pretty simple the return line goes in through this cooler on its way back to the pump.
Jan
Thanks,David
so if you want to upgrade to a quick ratio 12:1 box, and its close enough that the 4thgen hoses reach, you can just bolt on a later model box... just an idea.
On the older types of P/S pumps, you know where the fillerneck was soldered on, the oil has been so hot that the soldering has melted!! This is in extreme racing when doiing a lot of hard turning.
Jan
