Fuel fitting
Old Jul 12, 2006 | 04:50 PM
glock73110's Avatar
Default Fuel fitting
does anyone have a fuel fitting for fuelrail to 3/8
Old Jul 12, 2006 | 05:53 PM
leonpiper69's Avatar
read 67rscamarovette's stickey 67-69 basics. its in there.
Old Jul 12, 2006 | 06:39 PM
LS1MCSS's Avatar
I just used a 3/8 tube to an fitting, but you will have to use a small tube cutter and cut the tube right behind the raised part. There is still plenty of room for the fitting to work correctly. You can't really see it in the pic because of the covers, but it worked great and has ever leaked a drop.
Old Jul 12, 2006 | 06:48 PM
thats nice and all, but with this russel fitting you just pop it on. no cutting! no fabrication! stepone.... pop on, step two.... your done
modifing fuel line
Old Jul 12, 2006 | 07:12 PM
68shortstep's Avatar
yes i have one (russell) id sell it to ya 10 plus shipping (brand new never installed) pm me if you want it.
Old Jul 12, 2006 | 08:19 PM
glock73110's Avatar
PM sent
Old Jul 12, 2006 | 08:54 PM
pm and email replied
Old Jul 12, 2006 | 09:51 PM
glock73110's Avatar
Thank you Don I just called the parts house told em to stick that back order up thier donut
Old Jul 12, 2006 | 11:38 PM
bczee's Avatar
I started to use the Russell QD, but ending up going to my Tubing and A/C, had him braze on a AN fitting/end and that was it..$10.00 parts and labor.. I think If I offered him a six pack, I might have gotten it for free LOL
Old Jul 13, 2006 | 09:00 AM
stealth71's Avatar
bczee - Any reason you didn't use the russell fitting?
Old Jul 13, 2006 | 10:08 AM
bczee's Avatar
It was a better sealing solution for one, it turned out to be cheaper.. (I had already brought the Russell, so cost was not any real issue).
I screwed on a Fuel Pressure adapter and Gauge. Then the AN / SS hoses on to that.. I think if I had used the QD, it would have started to stick out pertty far at that point, even with a 90 deg elbow. I also have the Fuel Rail swap 180 deg so that the inlet is on the passenger side and close to the stock route of my 3/8" SS hard line. (AN and SS hoses from there to the fuel rail)
The only Con to going this route is that you don't have a Quick Disconnect.. but how offen do you need to remove the line ?
Old Jul 13, 2006 | 11:35 AM
Mr. Hyde's Avatar
I've got a dumb question about that Russell fitting: it's a 3/8" NPT male fitting, it does not accept a -6 female fitting, right? All my current fuel stuff consists of -6 AN fittings, so if I need to pick up a different hose end or adapter I'd like to be sure.
Old Jul 13, 2006 | 11:44 AM
no it is a -6 fitting
fyi------3/8 = -6
also in this istance 3/8 is describing the OD of the tube.
Old Jul 13, 2006 | 11:58 AM
Mr. Hyde's Avatar
fyi------3/8 = -6
Ok, duh on me. It looks identical but before I spend an hour in line at the local parts shop I figured I'd be sure.
Why don't they just list it as a -6 AN adapter
Old Jul 13, 2006 | 11:59 AM
bczee's Avatar
Yes.. 3/8" line to the Russel QD and AN -6.
Russell also makes the return line 5/16" QD to AN -6..
Old Jul 18, 2006 | 11:14 AM
glock73110's Avatar
Thanks Don the fitting was on my door step when I came in from work yesterday
Old Sep 29, 2006 | 10:34 AM
shifty`'s Avatar
So, let me get this straight - 3/8 NPT = -6 AN? That part is listed at the Russell Site (RUS-640850) as being quick disconnect on one side, 3/8 NPT threaded on the other.
Old Sep 29, 2006 | 12:03 PM
no it doesnt say 3/8 npt it may say 3/8 but shouldnt say npt..... the threads are diffrent on a AN fitting and NPT... but yes 3/8 (no NPT) = -6 AN fitting.... kinda confuseing , and the only reason i know is im a aircraft mechanic and AN fittings and braided lines are all aircraft use..
Old Sep 29, 2006 | 12:24 PM
bczee's Avatar
I think more correctly put is that a 3/8" dia tube/hose is equal to AN -6 in size.. It has nothing to do with the Thread size of a 3/8" tube/hose.
As is the following for sample of other sizes:
1/4" = -4
1/2" = -8
Hope this helps clear the air some.
Old Sep 29, 2006 | 12:33 PM
shifty`'s Avatar
Strange, I saw somewhere something that said that part RUS-640850 is NPT threaded. Summit is listing it as a 10mm-3/8" adapter though, so ... I suppose the QD is 10mm and the 3/8" is just the AN -6
