oil sender?
Old Jul 13, 2006 | 08:49 AM
kingb's Avatar
Default oil sender?
on the back of my 5.3 pointing straight up is a sensor that at first glance looks like an oil pressure sender. the wire running to it is a medium tan.
Old Jul 13, 2006 | 09:01 AM
nitrovette's Avatar
yep thats the oil pressure sending unit
Old Jul 13, 2006 | 10:05 AM
kingb's Avatar
why does everyone drill and tap the boss above the oil filter if there is already a sender existing
Old Jul 13, 2006 | 10:19 AM
nitrovette's Avatar
dont know, i just got a metric adapter and ran my autometer guage hook up right to that port.
Old Jul 13, 2006 | 10:55 AM
Schitzo's Avatar
I also just got an adapter. Easy and clean.
Old Jul 13, 2006 | 11:00 AM
MrDude_1's Avatar
two reasons..
one, some people are using both sensors... for example, using a GM gauge and the stock LS1 sensor in the back, and the side boss for an autometer gauge..
two, the side boss can easily be tapped to 1/8" NPT... a standard that matches 95% of the sending units out there... but the metric hole on the back of the block is harder to find an adapter for.. easier now that a bunch of people have posted where to find it.. but still, it used to be harder. thats why they did it.
i have my boss tapped and plugged, but only because its the supply port for my turbos oiling system.
Old Jul 13, 2006 | 01:00 PM
jannes_z-28's Avatar
One reason to keep it is that you can have the PCM light up the low pressure red light on your dash.
Jan
Old Jul 13, 2006 | 05:33 PM
kingb's Avatar
thanks fellas greatly appreciated
