Tach signal type
Old Jul 17, 2006 | 02:29 PM
dsrour's Avatar
Default Tach signal type
I couldnt find the answer on search. Would an aftermarket tach need to be set for 4 cylinder? tx
Old Jul 17, 2006 | 07:59 PM
LS1MCSS's Avatar
It did on my conversion.
Old Jul 17, 2006 | 09:41 PM
leonpiper69's Avatar
why????
Old Jul 17, 2006 | 10:29 PM
G-Body's Avatar
sawzall wielding director
The tachometer signal for an LSx is an output from the computer and GM decided to make it output a 2 pulse per revolution signal. The standard V8 signal is 4 pulses per rev. 4cyl`s have a standard pulse rate of 2 ppr, so to make a tach work on an LSx you need to either set it to look for a 4cyl signal or reprogram the PCM to have an 8cyl tach output.
Old Jul 18, 2006 | 12:18 PM
i never knew that , thanks.
Old Aug 16, 2006 | 08:21 AM
Meiko's Avatar
Hi,
*sorry bad english*
We put an LS1 in my 75 Corvette with a T56.
Problem:
The Tachometer is original (4 ppr) an the LS1 makes 2 ppr...
Engine run´s with 4000 RPM - the Tachometer tell me 2000 RPM
What must i do to use the original Tachometer?
We found no Parameter (settings) for the 2 ppr/4 ppr...
Thx
Meiko
from Germany
Old Aug 16, 2006 | 09:20 AM
70 LS1's Avatar
Conversion master
If you are handy with electronics you could use a frequency multiplier to convert the signal to 4 pulses per revolution.
Old Aug 16, 2006 | 10:34 AM
Meiko's Avatar
Hi Jeff,
2 ppr?
My Tachometer needs 4 ppr - or?
Better a multiplier...
Any fixes?
Meiko
Old Aug 16, 2006 | 11:45 AM
70 LS1's Avatar
Conversion master
Thanks, I fixed it.
Old Aug 16, 2006 | 08:42 PM
LS1MCSS's Avatar
Originally Posted by Meiko
Hi,
*sorry bad english*
Problem:
Thx
Meiko
from Germany
You can convert the signal with this. http://www.dakotadigital.com/index.c...rod/prd127.htm
Old Aug 16, 2006 | 10:27 PM
G-Body's Avatar
What type of tuning software are you using? I know that EFI Live 7 and HP Tuners have parameters to change the tachometer output.
Old Aug 19, 2006 | 03:50 AM
Meiko's Avatar
Thanks...
We found the parameter
And it works
Old Aug 29, 2006 | 01:52 AM
rleconey's Avatar
Can HP tuners reset the tach pulse to work with a vintage car?
(69 Camaro)
If so, how.
I already looked and even searched the help file
Dakota Digital unit is supposed to work for this application (ECM driving older coil driven Tachs But using the ECM to do it directly would be cooler
Thanks
