mounting your pcm?
Old Jul 18, 2006 | 08:28 AM
kingb's Avatar
Default mounting your pcm?
what is everyone using to mount there pcm. are they making brackets or using a factory bracket of some sort, i dont have a bracket yet
Old Jul 18, 2006 | 08:39 AM
Stu Cool's Avatar
I used a bracket from an S-10. I have a part number somewhere. I will look for it after work and post it. If you look at the journal in my sig, you can see pictures of it.
Pat
Old Jul 18, 2006 | 08:52 AM
joelvette's Avatar
i'd appreciate that part # too thanx joel
Old Jul 18, 2006 | 11:11 AM
glock73110's Avatar
not hard to make one I mounted mine under the dash over the glove box
Old Jul 18, 2006 | 11:20 AM
bczee's Avatar
I am using a stock 99' F-Body PCM mount.. I picked it up from the local Chevy Dealer for $13.00, But any mount can be modified to work, junk yard may be cheaper... I used some 1/8" x 1/2" steel and mounted it to the top of my Trans tunnel under the Dash. I will build a console around it and also put my ODBII connector, Check Engine light, Line Lock light and a few Gauges on the face of the console.. not hard to do at all !
Old Jul 18, 2006 | 11:58 AM
kingb's Avatar
thanks for the help
Old Jul 18, 2006 | 04:38 PM
Xtremes10's Avatar
im going to be re-using my s-10 mount, i can see if it has a part number or anything, you could use that or just mount it in the glove box
Old Jul 18, 2006 | 10:32 PM
Stu Cool's Avatar
The part number for the S-10 mount is 15995679. They charged me 19.69 at my local Chevy dealer, but that was list price. I'm sure if you shop some you can find one cheaper. Hope that helps.
Pat
Old Jul 19, 2006 | 09:32 PM
sssuch's Avatar
I used the top part of a truck mount bonded to a fiberglass lower portion that I made that bolts to the right frame rail . It looks like the factory installed it see pic. Stan 70 Corvette LQ4
Old Jul 20, 2006 | 09:15 AM
kingb's Avatar
i am in the process of building my mount, it also holds a factory 93 up camaro underhood fuse center. it should look pretty cool when im done. ill try to get some pics up.
Old Jul 20, 2006 | 04:37 PM
jimmyp's Avatar
how is everyone mounting the oddball 98 pcms?
