LS1 FD Iron or not?
Here are a few shots of the FD.
If it's a street car, I don't know how usable 675 horses are... I'd be sticking with a 402 LS2 aluminum block, n/a.
If you're doing a drag car, then it's a different story.
Many turbo guys have found that after making 600rwhp+ the ring seal on the LS1 blocks gets lost requiring a honing and new rings every few thousand hard miles. The solution seems to be an LS2 block and the ring seal problems are no longer an issue. hint hint
An LS2 block, stock crank, Eagle rods, forged pistons and low compression nicely flowing heads with LS6 intake/ported TB will support 1000rwhp. Quite a few people have literally exploded the FAST 90 3 piece intakes and the LS6 supports tons of power anyway more reliably.
As mentioned unless you plan to make this a drag only car put in a 402 stroker LS2 and be done with it. That will run mid 10's easy n/a with a T56 and traction. It will also keep the 50/50 weight balance to retain the great handling. Add a 100-150hp shot and you will be running 9's with traction. Adding 90lbs of iron block and a turbo setup will certainly affect the handling potential vs. n/a and all alum. Engineers would kill for 90lbs off of the front end of a car.
You are going to be pressed for space with a turbo setup in an FD. Best way would be move the engine back in the firewall for more room up front. There is very little room available. Battery in the bins is a must I would imagine. Forced induction LSx/FD is going to be a PITA. Hope your fab skills are good.
I'm interested in seeing a decently fitting turbo LS1 utilizing truck manifolds that fits under the hood in an FD without overheating constantly.
i don't know what you are building the car for or why you want 600+RWHP, but remember in a lighter car HP goes a longer way. a completely stock ls1 will take your car into the low 12s, and with minor mods it'll be solidly into the 11s.
anyhow, just two cents from a fellow FD owner
