TB 90 deg elbow
Old Jul 24, 2006 | 08:14 PM
LS-1<>57's Avatar
Default TB 90 deg elbow
Can anyone suggest where I can find a 90 degree rubber elbow to attach to my LS1 throttle body? My 57 chevy conversion leaves little room to go forward, so i gotta turn fast and connect to my MAF. Then I need advice on the best filter system to connect from there. Thanx in advance!! DK
Old Jul 24, 2006 | 09:42 PM
Stu Cool's Avatar
It's in the FAQ sticky at the top of the forum. Lots of info there worth reading if you are doing a swap.
https://ls1tech.com/forums/showpost....4&postcount=25
Good luck with your project
Pat
Old Jul 25, 2006 | 01:31 AM
StevenK's Avatar
would this be quick enough?
If so, airintakehoses.com.
Old Jul 25, 2006 | 09:48 AM
RFERG43's Avatar
Default 90 *
I got one from a local Fleet Pride truck parts store.
Old Jul 25, 2006 | 11:08 AM
Slo_240sx's Avatar
Intakehoses Dot Com.
Old Jul 25, 2006 | 11:39 AM
bczee's Avatar
I got my stuff from Jagsthatrun.com. It is all trial and error on what will work for you, But all of the Rubber and Aluminum Elbow have about the same turning radius. So you will have work with what you see in the pictures of StevenK setup.
You can also try the S&P Filter and MAF setup (costly), I have seen a few 57's with V8 Radiators location (else use a 6cyc radaitor setup) with Elec FAN fit tightly with the setup. Check out page 84 of there catalog (?).
Old Jul 25, 2006 | 01:49 PM
owen v8litew8's Avatar
I got a 4"-3.5" 90 degree reducer elbow and one 3.5" silicone coupler from www.atpturbo.com and its been great. I ran that to the MAF with a 3.5" steel pipe (conduit from home depot) to a 3.5" K&N filter from their online store and it was good.
then I recently elongated the MAF and IAT wires to locate the MAF down by the fenderwell. ran the elbow to a length of 3.5" aluminum pipe, a 3.5" rubber elbow then the MAF, then the silicone coupler as an insulator as it passes into the fender, then to a 3.5" aluminum elbow from ebay then the same 3.5" K&N filter, the new setup has been GREAT and with the IAT sensor so far from the engine the temps are much lower, especialyl combined with cooler intake air temps since the filter is right behind a bumper hole.
Old Jul 25, 2006 | 06:14 PM
ls67's Avatar
Default cobra head
go to the same site mentioned and look at cobra head reducing elbows if you dont have room for the stuff in the pic. but I think your flow will be better with a sweeping elbow.
intakehoses.com
Old Jul 25, 2006 | 07:18 PM
LS1MCSS's Avatar
Old Jul 25, 2006 | 08:26 PM
LS-1<>57's Avatar
Wow guys..!!! Thanx for all the come backs! There are alot more options out there than I thought.!! Looks like the setup that StevenK or LS1MCSS has is really close to what I need. I gotta go to the drivers side, since all my trans cooling lines and A/C lines are on the other side. You guys are great.!! I will post pics when I get it done! DK
Old Jul 25, 2006 | 09:41 PM
steveo346's Avatar
post pic of the 57 with the swap when you can
Old Jul 25, 2006 | 10:42 PM
patrick_rodgers's Avatar
Just like Chevy would have done in 1957 if they had the LS1
Old Jul 26, 2006 | 04:17 AM
67pete's Avatar
I love stock looking stuff!
Old Jul 26, 2006 | 07:37 AM
GTS346's Avatar
Have you looked at the new GTO's the pipe they run?
Ive got one here, has a pretty good 90 deg on it.
