Help on starting a swap
Old Jul 31, 2006 | 09:44 PM
Dstryr's Avatar
Default Help on starting a swap
Well here it is...
I've been reading this conversion forum and other ls1 conversions and have wanted to do one myself but I think it would be too far of an overwhelming project for me to do. I have the funds to do it but at 16 I don't have much more than basic car mechanic experience. This will be a project which I'd like to finish within 6 months
I would just like to learn a lot more about doing a swap and was wondering if you guys could suggest some general swap information. I was thinking of either doing an rx7 , second gen camaro , or like a 911 swap but i think the porsche would be way too hard even though I'm favoring that one the most.
Thanks,
Dennis
Old Aug 1, 2006 | 12:51 PM
RFERG43's Avatar
There is a ton of info for an RX7 swap at the link below. I did my RX7/LS1 swap with about the same experiece level as you. If you do a search on the
link below most of your questions will be answered. For an LS1/RX7 swap the big issues are the radiator/fan , clutch master, engine/tranny mounts, battery relocation and drive shaft. The mounts and drive shaft can be had for a reasonable price from www.hinsonsupercars.com. The stock wiring harnes can be used. Not all that many wires to hook up.
http://www.torquecentral.com/forumdisplay.php?f=11
Old Aug 1, 2006 | 07:48 PM
Dstryr's Avatar
What are some of the more common small car swaps that require no fabrication?
Old Aug 1, 2006 | 09:18 PM
Dstryr's Avatar
Would it be an okay project for a beginner mechanic to put the ls1 / t56 into an old ford mustang...
I know you'd have to change the mounts and stuff but would everything else pretty much work?
Old Aug 1, 2006 | 09:35 PM
G-Body's Avatar
sawzall wielding director
I don`t think there are any swaps that require no fabrication, but there are swaps that you can buy basically all the fabricated parts for. To swap an LS1 into a 3rg gen camaro you can buy the engine and trans mounts, you could buy an A/C compressor bracket to use the stock 3rd gen A/C comp and then you wouldn`t have to have custom A/C lines made. I think a 3rd gen f-body would be the closest you could get to something with no fab. If you get a EFI 3rd gen you can reuse the fuel tank, lines, sender, you just replace the fuel pump.
For an older mustang swap you would need mounts and a trans crossmember (as far as I know no one sells these premade) You would need to figure out a throttle cable and trans linkage setup. You would need to plumb it for high pressure fuel lines and have a tank made for fuel injection with baffels or us a "Tanks INC" fuel pump setup.
Old Aug 2, 2006 | 12:43 AM
Dstryr's Avatar
Okay well my next question is...how would I go about smogging a 3rd gen camaro with the ls1? An Rx7 would be pretty much along the same lines? meaning I could buy all of the fabricated parts already made?
Old Aug 2, 2006 | 01:20 AM
G-Body's Avatar
Smog depends on where you live, california you need to keep all the LS1 smog parts and get an underhood inspection. Illinois doesn`t look under the hood and you would have no problem passing even if you deleted a lot of the smog stuff. For the 3rd gen camaros you can buy all of the major parts already made. You might have to make some small brackets IE: the computer mount, but all the major stuff is available premade.
Old Aug 2, 2006 | 07:27 AM
RFERG43's Avatar
If you go the RX7 route, there is a lot of info on smog legal swaps on V8RX7.com
Old Aug 3, 2006 | 12:24 AM
Dstryr's Avatar
Do you think it would be that big of a project for me (as inexperienced as I am) to build a smog legal rx7 swap if I learn and research it enough? I really want to do this...I stay up a lot thinking about it all and how I would go about it all. I'm really excited about this. lol
Old Aug 3, 2006 | 12:42 AM
Dstryr's Avatar
Also, I want a 1993 + rx7 if I am going to do the swap...How much do you think I could get one without the tranny/ engine?
Old Aug 3, 2006 | 07:26 AM
crainholio's Avatar
Given that your idea of "research" appears to be limited to asking vague questions here, rather than searching and reading, I'd say it would be "that big of a project for you."
