PINKS ls1 s13
Our race will be on around the end of this season. Some time in october they tell us.
Don't forget, that pan holds 8.5 courts bitches!!!!!!!!!!!
and, total cost hmmm. Never really tried to figure it out. Retail value of my work into it would probably be around the 10k range.
-Alex
-Alex
-Alex
I had that fear. You can't see it in any of those pictures but there is an AN bung welded in the rear floor, and the one on the side of the kickout. That will transfer oil pools during acceleration. The one on the side doubles as the drain plug. I inpected the LS1 as much as time would allow. All the cam bearing where unharmed. This would lead me to believe that there an issue other than oil starvation. Plus like Pewterz said. The 6.0 made a handfull of passes with no problems. The one thing I wish I had done after a pass is drain a quart and see if it was still pooling enough to make alot of windage. The only way to starve it would be to have all 8.5 quarts in the motor and filled half way up the block in the back of the pan. That would take allot of sustained G's to keep it that high in the back before flowing back to the front. Plus it has a transfer tube. So I can pretty much say with confidence, It has absolutely no oil feeding issues.
What else do you think it might be. I would really like to know. It would be interesting to see what the rest of the connecting rod bearings look like. That would absolutely rule out oil starvation.
Thanks for reminding me.
