Using a tach as a speedo
Old Aug 4, 2006 | 08:29 PM
70 LS1's Avatar
Conversion master
Default Using a tach as a speedo
Tell me what you think of this idea. My speedo and tach are the same size with the same sweep to the gauge face. I am thinking of taking a tach and swapping the speedo gauge face onto it then either using one of those speedo ratio calibrator things or maybe tuning the PCM to give out the right pulses per mile.
Attached Thumbnails Using a tach as a speedo-speedo.jpg   Using a tach as a speedo-tach.jpg
Old Aug 5, 2006 | 01:25 AM
67RSCamaroVette's Avatar
who needs a speedometer? that'd be awesome if it worked, you dont REALLY need the translator though.. just tell your passengers your car is so fast that it jumps back in time, and that's why your speedo drops 30mph every time you shift. if all else fails, just grab a VSS speedo out of something else and merge the two. Keep us updated.
olly
Old Aug 5, 2006 | 12:44 PM
70 LS1's Avatar
Conversion master
It wouldn't drop when you shift. The tach signal and the VSS signal are very similar. If you put the speedo face on a second tach and hooked it up to the VSS, then it should work just fine as a speedo after you calibrate it.
I think I'm going to have to try it.
Old Aug 7, 2006 | 12:53 PM
70 LS1's Avatar
Conversion master
Anyone else have any thoughts on this or tried it themselves?
Old Aug 7, 2006 | 01:00 PM
MrDude_1's Avatar
you wont have a Odometer this way......
personally, id jsut send the gauge off to be converted over to a electronic speedo. while i havent done it, i know there are companies out there that do that sort of thing.
Old Aug 7, 2006 | 02:11 PM
70 LS1's Avatar
Conversion master
I thought about that. Classic Instruments quoted me about $2000 to do the speedo and tach.
Old Aug 7, 2006 | 02:29 PM
MrDude_1's Avatar
holy shiznit!
and they stay in biz with those prices?!
Old Aug 7, 2006 | 03:53 PM
70 LS1's Avatar
Conversion master
Their normal gauges are quite reasonable. Its just their custom sets.
Know anyone else that would convert a mechanical speedo to electric?
Old Aug 14, 2006 | 01:10 AM
G-Body's Avatar
sawzall wielding director
A few people have converted their mechanical speedos to electric so far. The only tricky parts are designing the new gauge face (unless you get lucky enough to find an electronic speedo with the same spacing as your factory speedo) and finding an electonic speedo with an odometer that lines up. I ended up cutting the odometer hole in my factory face so that I could read the odometer and then using my new overlay face to cover the old odometer hole. I didn`t really search too much for a perfect line up since I found an autometer electonic speedo on e-bay for $30. It even had an old style mechanical odometer instead of digital readout. I was able to just remove the pointer, put it behind my speedo face and drop the pointer from my original el camino speedo right on.
Old Aug 14, 2006 | 09:16 AM
70 LS1's Avatar
Conversion master
Thats cool, G-Body. The sweep on my stock gauges is way too much for an autometer. The electric tach is basically a speedometer that takes pulse inputs and displays an output. By swapping the speedo face on one, it would act the same but instead of showing engine RPM it would show speed which is basically derived from trans RPM.
Old Aug 14, 2006 | 11:39 PM
G-Body's Avatar
I didn`t look at the pic last night. You do have a large sweep on that face. I think that using a tach will work since I believe the tachometer signal is considered a square wave DC signal and that is what the PCM puts out. And I know that with EFI live 7 you can change the pulse output of the PCM since Jesse did that on my computer so that my cruise control would work. That would allow you to calibrate the tach/speedo.
