Park Neutral Switch
Old Aug 9, 2006 | 05:23 AM
OldSchoolFormula's Avatar
Default Park Neutral Switch
What are you guys doing for your park/neutral switches with automatics?
I read soemwhere that theres a switch that can be installed on the transmission itself, why didnt the f-bodies use it? Is it big and bulky?
Old Aug 9, 2006 | 09:13 AM
70LS1Nova's Avatar
whenever you buy your shifter, the switch should be included. If you're making your own (junkyard) shifter setup, you can buy a microswitch and make it work. It' s the same little switch used with nos kits.
Old Aug 9, 2006 | 04:09 PM
So a standard neutral safety switch will work? Using a B&M Quicksilver, FWIW.
Old Aug 10, 2006 | 12:16 AM
Mean Green z28's Avatar
As long as it lets the pcm know when it's in park/neutral, you're good to go! I wired up the wires from the switch on my cheatah shifter to the harness on my car that used to go to the stock shifter, works! Now I just dont have reverse lights
Old Aug 10, 2006 | 06:32 AM
LS1MCSS's Avatar
You can get a kit for the switch at Summit.
Old Aug 10, 2006 | 06:38 AM
Just poked around on the website, don't see anything? I see some Hurst neutral safety switches, but thats it.
Old Aug 12, 2006 | 01:28 AM
Ls1mc?
Old Aug 12, 2006 | 12:09 PM
LS1MCSS's Avatar
Here it is. http://store.summitracing.com/egnsea...DS=1&N=700+115
Old Aug 12, 2006 | 04:50 PM
Okay, so it is just a regular old neutral safety switch. Is it supposed to be a switched ground, or switched 12V? Which prong to the ECU?
Old Aug 13, 2006 | 12:54 AM
Hope the pics work. If not, if you have the VATS turned off, and give the starter solenoid power ... vroom!
Old Aug 13, 2006 | 01:21 AM
The VATS is turne doff. I just wnat the park neutral switch to work so the ECM can adjust the idle accordingly.
