T56 speedo sender to Autometer elect. speedometer
I am running a carbureted LS2 in my 67 Camaro. Can I use the stock speed sender to drive an Autometer electronic speedometer?
Thanks,
Jeff
Thanks,
Jeff
sawzall wielding director
You should ba able to, most autometer electonic speedos are programmable so you just have to calibrate it to your sender. Some autometers will only accept a sine wave AC signal so you will have to tap directly into the VSS feed, other autometers will accept a square wave DC signal so you can tie into the speedo output from the computer.
Originally Posted by LS1RS89
If you hook directly to the VSS you will throw codes for the VSS. You should have no problems running from the square wave PCM output as long as you have a programmable autometer. Mine works like a charm
So is everyone else saying hook it to the speed sensor on the trans?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I have read that a few times, but I have also seen a couple of posts where people could not get their autometer to work when hooked to the PCM and then it worked perfectly when they tied directly into the VSS. They did mention that if there is too much of a drain on the VSS the computer will start throwing codes. My speedo came with 2 input wires, one for square wave and another for sine wave, I hooked the square wave wire to the output of the computer and that is what I would recommend doing. But I always throw in the mention that some autometer speedos may not work like that and will have to tap into the VSS directly since I have seen that in a few posts.
I should probably dig up the old threads and see if I can find out what model autometer those people were using.
Yes, some of the non programmable autometers or just the older models would not read the square wave from the PCM. They will all work running straight from the VSS but you just have to run the VSS wire to the PCM also. Some people run from the VSS to the gauge and thats it but they tend to get VSS codes. On a carbed application then yup any 4000 ppm speedo or programmable will work
I am dredging up an old thread but can anyone tell me which pin the PPl/wht wire is hooked to? When looking at the trans from the driver's side, is it the front wire or the rear? Do I ground the other pin??
