Clutch Problem
Old Aug 19, 2006 | 02:39 PM
x-pauliber's Avatar
Default Clutch Problem
In this picture, is there anything missing from the quick disconnect? I'm having trouble sealing the disconnect into the slave cylinder. When I push on that little nylon down in the connector, it sticks and won't come completely out. Is there a way to fix this? If not, can I just change the hose end?
Old Aug 19, 2006 | 05:09 PM
LS1MCSS's Avatar
The connector should just push into the female half and lock. The only way to get a new hose, if you need one, is to buy a master cylinder.
Old Aug 19, 2006 | 05:27 PM
x-pauliber's Avatar
Is there a way someone can put a new end on my line? I have enough excess line to reach the female end on the tranny.
Old Aug 20, 2006 | 06:00 AM
LS1MCSS's Avatar
I did a lot of searching on this when I was doing my swap. The salvage yard broke the connector off my line when they were pulling the engine/tranny. I couldn't find a good way to change the connector that didn't seem like a lot of trouble for something that might not be dependable. I finally just ordered a new master cylinder from gmpartsdirect. They come pre-bled and ready for install. Does your connector not go all the way in, or just not seal when it does?
Old Aug 20, 2006 | 08:21 AM
JoeZ's Avatar
I have a spare (unused) master cyl I bought just to get the line....only to find out that my friend had his original MC after upgrading to McLeod. If you need it just shoot me a PM and we can work something out.
Old Aug 20, 2006 | 01:28 PM
x-pauliber's Avatar
It goes in the whole way but it won't seal.
