Low mount AC on a 72 Stingray?
Has anyone tried to fit an AC down low on a 68-82 Corvette? I've got the standard 6.0L truck low mount setup and it looks like it would be very close to the engine cross member and passenger motor mount. Has anyone done it? Pictures... Thanks This setup uses a single belt instead of 2 belts. You can make the stock compressor work, bit it is way too much trouble, and it is not that good a solution when you are done. Don't forget, that the engine centerline in you car is offset 1" to the passenger side to accomodate the IRS, so the clearance to the Passenger side frame rail is TIGHT! I have sen many people take measurement, and decide that there was enough clearance for an item in a Corvette, only to be derailed when the engine was mounted in the correct offset position.
Regards, John McGraw
Is that why? I always assumed it was go get a balanced side to side weight distribution with just the driver in the car. And I didn't even notice it until I dropped the new motor in.
If forced induction is your goal the LQ4 or LQ9 would be a good choice but if it’s a normally aspirated build why not go with an aluminum block to save some weight. There's about an 80lb difference between the two. The hood clearance issue is not a problem when an lS1/LS6 intake is used. And damn this truck Intake is UGLY!!!
Back to the Low Mount AC install, I'm planning to install a triangulated 4-link rear replacing the IRS. So do you think centering the motor between the frame rails would help the AC install? I know it would give me more room for the turbo on the passenger side. This one needs all the room it can get...
I'll know more once I mount the engine in the frame and run the turbo plumbing. Thanks for the input...
