92 camaro ls1 wiring...PLEASE HELP?!?!
when i put the ls1 in a took apart the factory 305tbi harness and removed all sensors and left only a/c circuit. the red fusable links to the junction block and TO THE STARTER.(am i suppost to keep those?) i removed the fan relay and wiring but left the fuel pump relay and wiring. and once the motor was installed i hooked up the fusable links to the starter and the ones to the junction block. also i put what was left of the grounds on the back of the old 305 cylinder heads to the ls1 cylinder heads.
the new harness had 8 wires to plug in to make everything work. only 2 were needed to make the motor actually run. 12v switched i plugged into the acc hole on the fuse block under the dash. and the other wire was a cranking signal which i connected to the purple wire that went to the starter on the 305 setup.
i have no idea what to check for or anything. at this point i am at a dead end of diag. if you have any suggestions please suggest. no matter what i will check anything. vatts? power at the old ecm? ground? idk im confused and frustrated.
any and all help would be greatly appreciated.
ryan
Vinh
